Suspension knocking noise when Cold.
Haven’t been able to record the noise. However when the car is cold, there’s a definitive knock noise coming from the passenger side of the car, it occurs anytime the car is rolling and with engine off
Clicks/Knock accelerates with speed and left turns but not right turns. Once the car warms up it’s fine.
Thinking maybe Wheel-bearing or CV axle?
I was having a similar issue with a kind of clicking/chattering when car was cold and putting the car in reverse. Chatter got louder when on the throttle to back up....
Long story short, I recently had my motor mounts replaced and have not heard the noise since. Just another area to consider.
Good luck!
Good luck!
Good luck!
Good luck!
@Xavier Smith II that is where I would place my bets as it solved my similar issue. That is frustrating if you just replaced the mounts recently. Did you use OEM mounts?
I would think so too, but the knocking noise is on the other side of the car.
