C63 AMG (W204) 2008 - 2015
C63 amg random "sloppy" start
Old Mar 31, 2023 | 08:40 AM
IMfam0us's Avatar
2011 C63 p31
-Hey guys looking for some insight and direction here with my 2011 C63 with 110xxx miles on it. I've been getting a random "sloppy" start up, I don't know how else to describe it. Usually starting up after sitting over night is a normal crisp start, but if it sits for 30mins..... a few hours..... 6 hours....., then its a 50/50 that is will start up sloppy and its getting progressively more common. Always drives perfect after start up with no odd idling or misfires, no codes showing up either. I'm looking to see if anyone else has experienced the same.
-Recent maintenance within the last 5k: spark plugs, injectors, rebuilt cam adjusters (relearn program done), air filters and fresh oil change (the other day)
Appreciate any help as I couldn't find anything similar with searching. **Added video sound clips a few replies down** Thank you,
Old Apr 1, 2023 | 03:15 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
I think I would start by replacing the injectors, spark plugs and air filters then test it for long enough to confirm if the problem is resolved or not.
These parts are part of a routine maintenance refresh so no problems if it is not resolved and money on parts not wasted.
Old Apr 1, 2023 | 08:40 AM
go team's Avatar
2012 C63, GL63, 1989 300CE
Vacuum leak
Old Apr 1, 2023 | 10:16 AM
IMfam0us's Avatar
2011 C63 p31
All of those have been done within the last 5k (stated at the end of post)
Old Apr 1, 2023 | 10:20 AM
IMfam0us's Avatar
2011 C63 p31
Originally Posted by go team
Vacuum leak
i can try doing a spray test with carb cleaner in some common spots and see if i get an idle change. Could have a shop do a smoke test if i can't find any. Thank you for the input
Old Apr 14, 2023 | 08:42 AM
IMfam0us's Avatar
2011 C63 p31
Checked for vacuum leaks and found nothing. Tried to capture the start up sound on video. These were both taken after sitting for maybe 20mins after being at full operating temp.
Old Apr 14, 2023 | 11:30 AM
PeterUbers's Avatar
Did you say you replaced the battery?
Old Apr 14, 2023 | 12:11 PM
IMfam0us's Avatar
2011 C63 p31
I checked yesterday on the battery, it is dated 5/2021. Checked voltage at the posts while the car was off and running. Voltage was where it should be and constant, but I haven't had a second person to check while starting the car. But, last fall the battery did drain to the point of not being able to start one day while waiting in a parking lot with just the radio going. Has never drained to that point again.
Old Apr 14, 2023 | 12:24 PM
PeterUbers's Avatar
could still be the battery. Like you said you didn't load test it.
you could jump-connect it with another running car (battery to battery) and the starting it and see if it sloppy starts in the circumstances you describe - if not - then it may be the battery
Old Apr 14, 2023 | 12:28 PM
IMfam0us's Avatar
2011 C63 p31
Thank you for the input! I'll see if I can get someone over this weekend to help me load test it and see if the voltage is taking a big drop. I had completely forgotten about when the battery had drained out to a no crank last fall....that could have done it and the battery just never full came back. I'll update soon
Old Apr 14, 2023 | 02:47 PM
eightysixtuned's Avatar
W211 E63 AMG
as stated, could be your PCV or internal intake manifold leak. separate from that, any competent tuner should be able to direct you to area's to dig into based off datalogs.
Old Apr 24, 2023 | 10:20 AM
IMfam0us's Avatar
2011 C63 p31
Waiting on the fcp euro package deal to arrive, went to take everything apart and lucky me.....the bolt holding the pcv in snapped off lol More fun while waiting now
Old May 15, 2023 | 04:59 PM
IMfam0us's Avatar
2011 C63 p31
late update on things. New oem pcv, intake mani gaskets, intake mani cleaned up and resealed, new bolts. Definitely made a difference but still an occasional start up when the engine is warm/hot that isn't the normal m156 crisp start up.
Old Jul 17, 2025 | 12:01 PM
dreedo63's Avatar
2011 C63 AMG
Any update on this? Mine has been doing the same thing lately, and I agree the term I would use is a “sloppy” start
Old Jul 17, 2025 | 12:54 PM
IMfam0us's Avatar
2011 C63 p31
No updates, sorry. Still does it randomly. Dealer and indy shop said they couldn't see anything wrong. Soneone said crank position sensor could be failing. I haven't tried swapping it out yet. Besides that funk....it still has been running as it should. If you figure anyrhing out, reply for me so we know.
Old Jul 18, 2025 | 06:27 AM
DRBC43AMG's Avatar
Wonky battery perhaps?
Old Jul 18, 2025 | 03:02 PM
0fc5dccf's Avatar
Can you please re-upload the videos? Mine had one "sloppy start" where it cranked for a few seconds and stumbled for a few seconds before it started up. It has only happened once in the last two years i've owned my car, so it hasn't really bothered me much but it is something I noticed.
Old Jul 25, 2025 | 05:15 PM
C63R's Avatar
C63 W204 Coupe
Did you ever solve. My car...
Replaced the secondary air pump as that had an error
Replaced one Cam sensor as that had an error
One day the PCV body went BANG during a a poor sloppy start and I had to bodge it on to get home but replaced that too along side a new crank sensor tucked at the back of the engine
car is driving better and batter the more I drive it and obviously fix it, next is engine mounts..
But the main issue
Cold starts are 100% perfect EPIC
BUT. WARM/HOT starts are embarrassingly bad, sometimes the car conks out, most of the time I cut it off then do a quick re-start
battery is healthy. no leaks far as I know
Old Jul 27, 2025 | 02:06 PM
Systemsone's Avatar
2011 Amg 63
i have this same problem. did you ever resolve this?
Old Jul 27, 2025 | 02:08 PM
Systemsone's Avatar
2011 Amg 63
Old Jul 28, 2025 | 05:50 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Charge your battery see if that helps
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jul 30, 2025 | 11:51 AM
0fc5dccf's Avatar
it's not the battery.
Old Aug 6, 2025 | 05:26 PM
IMfam0us's Avatar
2011 C63 p31
Hey, sorry for the late reply. I swear I replied the same day but dont see it. Its still there randomly, not as bad but still there. A few ppl said the crank position sensor might be going out. Later this year I might do that along with coilpacks as those are still original and I get a slight miss when sitting at a light.
Old Aug 6, 2025 | 05:33 PM
IMfam0us's Avatar
2011 C63 p31
I don't have them any more. I could try to catch it one of these days. Its kinda turned into something I just live with.
Old Aug 6, 2025 | 05:36 PM
IMfam0us's Avatar
2011 C63 p31
Battery has been replaced with a brand new one along my journey. Didn't solve it.
