C63 AMG (W204) 2008 - 2015
LSD or no?
Old Nov 2, 2023 | 09:56 PM
Aadenc63's Avatar
2013 Mercedes c63
LSD or no?
I have a 2013 Mercedes c63, and I was wondering how can I find out if my car has a lsd? I did a vin decoder and it said I had transmission code version 30, not sure if that means I have a LSD, usually when I do burnouts both wheels do spin so im guessing I do? My car is not a P31.
Old Nov 2, 2023 | 10:19 PM
menaceAMG's Avatar
2013 C63 AMG PP Coupe
The data sheet will have a code for 471. You can also lift the car, put in neutral and spin a tire, if the other moves in opposite direction then you have an open diff.
I just put a os giken in mine, probably overboard but we'll worth it to me, drives just amazing compared to before in a corner and slides are predictable.
Old Nov 2, 2023 | 10:22 PM
Aadenc63's Avatar
2013 Mercedes c63
Yeah I just checked it right now and no 471 , maybe I’ll swap for a LSD , I don’t do donuts or burnouts to often so im not to sure ,
Old Nov 2, 2023 | 11:02 PM
Mort's Avatar
The LSD will greatly improve the performance coming out of a corner as well if you are driving aggressively.
Old Nov 3, 2023 | 03:31 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
agree'd that oddly, C63's lay down 2 tracks when burning out and can do a decent amount of donuts and drifting to make it seem like it has an LSD. the W211 chassis surely does not do this and may be attributed to the heavier weight and wider tires. 2 tracks are laid down but donuts and drifting is not possible with a E63 as it will only spin 1 tire.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 3, 2023 | 06:01 PM
AMGSPY's Avatar
2014 C63 507 Coupe
menaceAMG, Is that true? I always wondered about that and thought you might have more of a safety cushion built in with an open dif. Maybe not? It makes sense I guess if it gives you more overall control and feel. Is that the case? Mine has an open dif..
Old Nov 4, 2023 | 07:22 AM
menaceAMG's Avatar
Control is way better, I wish I upgraded earlier. Advice to anyone would be to do the finned cover and do the DSS driveshaft along with it.... Or at least collect the parts and install at once.
Old Nov 4, 2023 | 12:22 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Where does one source the finned diff cover from? Surely something came with it from the factory. 👍
Old Nov 4, 2023 | 12:44 PM
menaceAMG's Avatar
I ordered from mbpartscenter, I googled and found the part numbers so thanks to others who did previously.
