Valve Cover Gasket Bolts
N000000002439 - Google Search
Additional information
Diameter: 6mm
Length: 25mm
Strength / hardness class: 8.8
Thread code letter: M
Thread pitch: 1mm
Height (packed): 2cm
Length (packed): 3cm
Volume: 12cm³
Weight: 0,007kg
Width (packed): 2cm
EPC makes no reference to any other bolt, but do reference both plastic and aluminum covers.
Regards,
Joe
Diameter: 6mm
Length: 25mm
Thread pitch: 1mm
Volume: 12cm³
Weight: 0,007kg
Width (packed): 2cm
Regards,
Joe
The bolt length and thread pitch between the two bolt variants is indeed the same, but the steel bolts without the integrated sleeves for the PFL metal covers will usually break the FL plastic covers.
