Pics of my Gen 5 3.0L Whipple Build
Subscribe
Dec 20, 2023 | 02:17 PM
VRP Gen 5 3.0L Whipple
Weistec Trunk Tank
Custom Billet Power Steering Tank relocation.
Custom AMG Black Series engine plaque, etched in stainless steel with a high gloss clear on top.
Custom Race Camshafts, SLS Lifters, Adjuster Plates, all new hardware and gaskets.
Side comparison between custom spec cams and factory camshafts.
Full 3" Exhaust, LTH, Double X-Pipes, 4.5" CF Quad Tips.
Wavetrac Install
Weistec Transcooler with aux oil cooler and fanpack.
Deleted SAI system and all emissions crap to mount the trans cooler in this location.
Billet Engine Mount and Billet Trans Mount
Antigravity Lithium-ion Race Battery. 10lbs battery vs 45lbs factory battery.
Custom Steering wheel with JQwerks Magnetic Paddle Shifters.
AMG gas cap.
Final look with Chalk Grey Wrap and AMG Edition One side decals.
First startup with new build.
Reply 12
Dec 20, 2023 | 02:18 PM
Installed a 8" Android head unit to monitor my Intercooler Temps, Engine Coolant, Trans Temp, Fuel Pressure, Voltage, ect. with AMG Performance media style gauges.
Fabbed some custom aluminum intake pipes to go in the factory intake scoops location. Dropped my air intake temps about 20F*.
Installed a Blackboost Thermostat, dropped my engine coolant and oil temps by 20F*.
Had some custom Beadlock wheels made to match my HRE wheels so I can run some 305 MT ET Street R's.
Reply 9
Dec 20, 2023 | 03:47 PM
Your car is what I dreamt my 507 would evolve into.
Thank you for sharing!!!!!
Reply 1
Dec 20, 2023 | 05:27 PM
Alex at Legitstreetcars is building a similar setup on his 507, pretty cool build series to watch!
Reply 1
Dec 20, 2023 | 06:34 PM
You should be very proud of your build. It's exceptional in every aspect. As to the cams, if that's the factory cam on the right, no wonder they chew up lifters. That is a really sharp profile with a fast ramp to it! Are yours a similar total lift but with more duration? Less lift but more duration? I don't know which way these guys rotate, but if your spec cam is on the left, is the gentle ramp on the right side of the cam opening the intake? I am totally guessing here, but is the idea, with your blower, start opening sooner and longer because we are coming to the party early? Merry Christmas
Reply 0
Dec 20, 2023 | 06:38 PM
Looking like a great build, nice work!
Reply 0
Dec 20, 2023 | 08:55 PM
Quote: You should be very proud of your build. It's exceptional in every aspect. As to the cams, if that's the factory cam on the right, no wonder they chew up lifters. That is a really sharp profile with a fast ramp to it! Are yours a similar total lift but with more duration? Less lift but more duration? I don't know which way these guys rotate, but if your spec cam is on the left, is the gentle ramp on the right side of the cam opening the intake? I am totally guessing here, but is the idea, with your blower, start opening sooner and longer because we are coming to the party early? Merry Christmas
The cams have a bit more lift with more duration than the factory cams, the valves stay open longer for maximum airflow.
Quote: Looking like a great build, nice work!
Thanks man, would be cool to see your ML with the 3L Whipple.
Reply 1
Dec 20, 2023 | 09:51 PM
Quote: 8895747[/url]]Thanks man, would be cool to see your ML with the 3L Whipple.
Ha, not gonna lie, the thought has crossed my mind! I’ve already got one 3.0L Gen5 Whipple in my stable…another one would rock! Although then the wife would want one on her Mustang too haha. Here’s the one on my Camaro:
Reply 1
Explore
Dec 20, 2023 | 10:34 PM
Quote: Ha, not gonna lie, the thought has crossed my mind! I’ve already got one 3.0L Gen5 Whipple in my stable…another one would rock! Although then the wife would want one on her Mustang too haha. Here’s the one on my Camaro:
Clean setup! Love the white Whipple!
Reply 1
Dec 21, 2023 | 07:24 AM
Quote: 8895789[/url]]Clean setup! Love the white Whipple!
Thank you! Runners are getting sent off this winter to be drilled for port injection… 8 injectors can’t give me enough fuel so I’m hoping 16 does the trick!
Whats next for your rig? Dyno time? Drag strip runs? Or just enjoy the hell out of it?
Reply 0
Dec 21, 2023 | 10:45 AM
Nice to see you came to your senses about the hot air intakes you originally had on there. Still no filters though? 🤔
Reply 0
Dec 21, 2023 | 12:04 PM
Quote: Thank you! Runners are getting sent off this winter to be drilled for port injection… 8 injectors can’t give me enough fuel so I’m hoping 16 does the trick!
Built trans from SHR is next on the list, then maybe more boost. Going to enjoy it this winter and take it to car meets and put some miles on it!
Quote: Nice to see you came to your senses about the hot air intakes you originally had on there. Still no filters though? 🤔
No filters really needed on a nice sunny weekend driver, I did add turbo mesh screens to keep large debris out tho.
Reply 1
Dec 21, 2023 | 04:03 PM
Quote: No filters really needed on a nice sunny weekend driver, I did add turbo mesh screens to keep large debris out tho.
You're slowly sanding the **** out of that sweet supercharger. It really needs high-flow filters of some kind. 👍
Reply 1
Dec 21, 2023 | 04:22 PM
Quote: You're slowly sanding the **** out of that sweet supercharger. It really needs high-flow filters of some kind. 👍
If it was my daily driver I'd look into adding air filters, it only gets driven once a week. I'll pull the lid off after 5-10k miles and inspect the rotors. 👍
Reply 0
Dec 21, 2023 | 07:43 PM
one of the cleanest if not the cleanest builds on MBWorld!
Reply 3
Dec 21, 2023 | 08:41 PM
I agree no filters is silly. You are going to run into some added wear on multiple components for almost no benefit. But to each there own
Reply 1
Dec 21, 2023 | 10:13 PM
Quote: one of the cleanest if not the cleanest builds on MBWorld!
Thanks Barry.
Quote: I agree no filters is silly. You are going to run into some added wear on multiple components for almost no benefit. But to each there own
It'll be fine.
Reply 0
Dec 22, 2023 | 01:53 PM
Filter protection aside, those intake pipes are gorgeous. Along with the SC (of course) they really clean up and transform the look engine bay.
Reply 1
Dec 22, 2023 | 06:36 PM
Yeah. what Barry said. I have to tip my hat as well. Just Wow! Enjoy!
Reply 0
Dec 23, 2023 | 02:44 PM
Quote: Filter protection aside, those intake pipes are gorgeous. Along with the SC (of course) they really clean up and transform the look engine bay.
They complete the look for sure!
Quote: Yeah. what Barry said. I have to tip my hat as well. Just Wow! Enjoy!
Got the new meats for the beadlocks delivered today.
Reply 3
Dec 23, 2023 | 10:07 PM
Reply 2
Dec 24, 2023 | 12:24 AM
Crazy tires 👌
definitely need to get a wide body on mine those look way too good
Reply 1
Dec 24, 2023 | 07:39 AM
I love this build. Absolutely bonkers and made the E63 into something wild.
Do you have any numbers on this setup?
Reply 1
Jan 1, 2024 | 07:40 PM
Got the beadlocks installed, they got the specs dialed in perfectly.
Reply 4
Jan 2, 2024 | 01:17 AM
Awesome build photo dump. Looks like everything came together very nicely. Are you local to Dallas area - Top Speed license plate frame.
Wheel fitment and tire choice are spot on. Let us know how it does on the dyno.
Reply 0
