C63 AMG (W204) 2008 - 2015
Misfiring Cylinders 3, 6, 7
Old Nov 2, 2024 | 06:35 PM
0fc5dccf's Avatar
I need more brains to help me figure out why my 2013 C63 is misfiring on cylinders 3, 6, 7. It started misfiring on me one day while idling at a red light. After I got the car home, I found one very obviously burnt and slightly melted coil pack in cylinder #5. I replaced that one coil pack with an AutoZone coil pack while I was waiting for a Mercedes one to get shipped, but noticed that now i'm getting misfires in other cylinders as well.
Things i've tried so far:
  • Changed all coil packs to brand new Mercedes AMG coil packs
  • Changed all spark plugs to brand new NGK spark plugs
  • Changed all fuel injectors to brand new Bosch factory-spec fuel injectors
  • Unplugged the MAF, still misfires
  • Unplugged one bank of cam sensors, still misfires
  • Swapped around coil packs, still misfires on the same cylinders
  • Swapped around spark plugs, still misfires on the same cylinders
  • Traced the wiring for all 8 coil packs back to the ECU harness and verified it was fine
  • Sent the ECU to a local ECU test and repair centre, which said I had damaged ignition drivers and they swapped out the ignition driver but it still misfires on the same cylinders
I've checked the coil packs for spark and there is no spark present at cylinders 3, 6 and 7. However, I know the coil pack is getting 12v power and ground and I've manually traced the wires with a multimeter back to the ECU plug and verified there were no shorts or breaks. I am going to replace the O2 sensors next but I don't see how a bad O2 sensor will cause no spark to be sent.
Can someone help me find a wiring diagram for the coil pack connector and help me trace it back to the ECU so I can double check each pin in more detail. When I checked the harness earlier I just verified each coil pack had 12v and ground and had continuity to the ECU harness.
Old Nov 4, 2024 | 11:49 AM
0fc5dccf's Avatar
Just keeping an ongoing tally of things i've tried:
20241103 - Cleaning all four cam position sensors, didn't get to crank position sensor. Exhaust cam position sensors had some silver sludge on them. Wiped it all off, tried starting. Still has a miss on 3, 6, 7. Tried unplugging passenger side exhaust bank. Still misfires. Plugged in passenger side and unplugged driver's side exhaust bank. Still misfires.
Old Nov 5, 2024 | 12:50 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
What does the oil look like? Any mixing of coolant with oil?
Old Nov 5, 2024 | 12:54 PM
0fc5dccf's Avatar
Oil looks fine, no mixing of coolant and oil. While checking and cleaning my cam position sensors, I noticed some silver paste that was probably fine ferrous metal that had collected around the hall sensor. That's the only oddity I found in the oil so far:
Old Nov 5, 2024 | 12:59 PM
0fc5dccf's Avatar
Here's me quadruple checking the wiring harness again. I checked all eight coil packs, all four pins for power and ground, and also traced the signal wires back to the ECU and the confirmation wire which I think Mercedes is just tying to ground. Also checked all of the ground points bolted to the heads and I did find a loose ground on the driver's side bolt near the cam control solenoids. I tightened that ground up but it didn't make a difference. Also checked the capacitors on each head that looks like it's being used as a noise filter. Everything checks out.
Old Nov 5, 2024 | 01:02 PM
0fc5dccf's Avatar
Old Nov 5, 2024 | 01:50 PM
blay127's Avatar
W204
check the wiring on the injector harnesses? problem sure sounds electrical. weird it would pop up on three random cylinders at the same time though.
what part of the houston area are you in?
Old Nov 5, 2024 | 02:17 PM
trigital's Avatar
W213 All-terrain
Originally Posted by poots
Combustion misfire... check fuel pressure.
Old Nov 6, 2024 | 07:51 AM
MTBSully's Avatar
2006 E55
Interesting. How are you checking the harness? Are you just checking both ends with a multimeter for continuity? Where did you snag the wiring diagram from?
Old Nov 6, 2024 | 11:45 AM
0fc5dccf's Avatar
Yup, this is the really frustrating part. Always those three cylinders, no spark. Midtown area.
Around 406kpa, which is normal at idle
Yes, checking both the ECU side and the coil pack side for continuity and unusual resistance. I also wiggle the harness around to make sure there's not a loose connection. All connections were less than 1ohm and also didn't have any intermittent connections. You can get the wiring diagram from Mercedes, it costs $28/week https://www.startekinfo.com/home
Old Nov 6, 2024 | 11:52 AM
trigital's Avatar
W213 All-terrain
Intake air leakage and a compression test should be your next step if pressure is OK and injectors is properly installed.
Old Nov 6, 2024 | 01:38 PM
0fc5dccf's Avatar
Yes, taking apart the intake manifold and checking for leaks is going to be eventually down the line, but how does intake manifold prevent the coil plug from igniting? The main issue here is a lack of spark signal from the ECU.
Old Nov 6, 2024 | 02:26 PM
blay127's Avatar
W204
if you've confirmed everything is sound to and from the ECU and still not getting spark on those cylinders, i'd say there's an issue with the ECU. i know you sent it out once, but maybe get a second opinion on it elsewhere?
Old Nov 6, 2024 | 02:49 PM
trigital's Avatar
W213 All-terrain
You have combustion misfire, means that nothing electric is involved. Just missing fuel or too much fuel....and if it is too much, then the oil could become diluted or even the catalytic converter could melt.
If you trust the diag machine,
Old Dec 10, 2024 | 09:47 AM
0fc5dccf's Avatar
I believe this was the answer. Took the ECU from the original shop that said they "fixed" it and charged me $600 to a different shop. Paid $40 for them to test it and they confirmed that no ignition signal was being sent on cylidners 3, 6, 7.
They don't think the ECU can be repaired, or at the worst case they can attempt repair but can't guarantee the repair will work. I'm shopping for a new ECU right now.
Old Dec 10, 2024 | 10:04 AM
MTBSully's Avatar
2006 E55
if it is an ECU issue, anyone know if you can buy another ECU and drop it in? Or does it need to be coded to the vehicle? If so, can this be done using STAR? Or dealership only?
Old Dec 10, 2024 | 10:07 AM
0fc5dccf's Avatar
It is definitely not drop-in plug and play. The ECU is considered a theft-relevant part and can only be ordered in person at the dealership with ID check. After it is ordered it needs to be coded for the car before it can be used.
Aftermarket shops can clone the contents of the old ECU to the new ECU, as long as the ECU memory is readable. Both of the shops I worked with are able to perform this service for about $150.
Old Dec 10, 2024 | 10:10 AM
MTBSully's Avatar
2006 E55
Care to share what shops you used? I don't think I have an ECU issue, but i'm not ruling it out either, so im trying to be prepared. Hope you get this sorted out! Keep us posted when you do!
Old Dec 10, 2024 | 10:15 AM
0fc5dccf's Avatar
First shop I went to.
I don't have any ill will towards them. I dropped off the ECU and was very clear to them that I had no rush for any of this and mistakes happen, I've already spoken to the owner and he assures me he will personally take care of it.
https://maps.app.*******/BSd9Bck42khPdrhTA
Second shop where I got a second opinion where they confirmed the coil pack drivers were bad:
This place charged me $40 just to run the ECU on their test machine, which confirmed that no ignition signal was being sent out.
https://maps.app.*******/Bab3A5RTuYHkCDb36
Right now the car is waiting on ARP cam bridge bolts and "Stage 1" cams from 63Motorsports, which are currently backordered until early next year so I don't have a rush to get this fixed right now. I'll keep you guys updated on what's going on.
edit: looks like I can't paste Google Maps links here? First one is TRN Electronics, second one is 1800ECM. Both are in the greater Houston area.
Old Dec 10, 2024 | 10:17 AM
MTBSully's Avatar
2006 E55
https://maps.app.google.com/BSd9Bck42khPdrhTA
maps.app.google.com/Bab3A5RTuYHkCDb36
Map links don't work for some reason. Either way, hopefully this gets your sorted! The 63 motorsports stuff is super nice and their customer service is excellent too!
Old Dec 10, 2024 | 10:22 AM
0fc5dccf's Avatar
Yeah I don't know why it wouldn't let me paste Google Maps links. Anyway, I already have the 63Motorsports cam phaser repair plates, titanium cam gear bolts, and ARP cam front cover bolts and were very impressed with them. When I was doing the cam phaser plates, I noticed the driver's side intake bank had some excessive wear on the cam lobes, so I also ordered their "Stage 1" camshafts and a set of BS buckets and ARP bridge bolts. They're a bit backed up from SEMA so they're catching up on stock. Hopefully next year the car will be running again
Old Dec 11, 2024 | 12:15 AM
roadtalontsi's Avatar
10 C six trizzle
Ecu seems likely, or a loose / bad ground. You should also go ahead and do a compression and leak down test. You never know. Wasting a lot of money and time on electronics when it could be a mechanical issue. Sure unlikely to have that occur on 3 cylinders, but those maybe the ones showing issues first, or the ecu is interpreting them inaccurately.
Old Dec 11, 2024 | 02:52 PM
0fc5dccf's Avatar
Check out the updates in the thread. Wiring is fine, there are no issues with wiring or coil packs or spark plugs. Relative compression test was fine as well, so there's no need for a dedicated leakdown and compression test. It's already confirmed as a bad ECU that was damaged by a coil pack dying.
Old Jan 12, 2025 | 11:30 PM
0fc5dccf's Avatar
Some updates - I mailed the ECU to ECU Pros, who confirmed that someone had replaced components, but did a poor and incomplete job so the original fault was never repaired correctly. They said they were confident in being able to repair the ECU so I paid them ~$400.
A week later I got the ecu back and did more testing. I now have spark on all 8 cylinders, but now i'm not having fuel in cylinder #3. I was able to confirm this by checking the injectors with a hall effect sensor, and also by swapping out injectors - somewhere now the ECU is not sending an injector pulse to cylinder #3.
In the meantime I have sent the ECU back to ECU Pros to have them inspect the injector drivers and see what's going on - will update when I get the ECU back.
Old Jan 13, 2025 | 10:27 AM
blay127's Avatar
W204
man almost there. that sure sucks but hopefully they get you fixed up. thanks for the update!
