High Coolant Temperature After Black Series Lifters + C63 MS Stage 1 Cam Phaser
Also, if in the affected range, are the head bolts original?
The lifter / cam adjuster jobs have nothing to do with the cooling system, so it seems unusual for this to suddenly appear.
Are you sure there are no leaks from moving the hoses around?
Pressurizing the cooling system and checking for leaks would be a good step to take.
Thank you guys for taking the time to answer my questions I very much appreciate it.
Procedure from WIS attached. Basically, you remove the shields / trays, pressurize the system and start inspecting carefully for leaks.
Unfortunately, I'm not aware of a universal tester kit that works with the M156, which I learned the hard way in the middle of diagnosing something, prompting me to order the MB-specific tools.
If by chance you're local to NJ, happy to help you out.
Otherwise, your options are to find a compatible kit, order the MB one (part numbers in the attachment) or take it to an independent shop experienced with these platforms and have them check the system out.
A different route would be to add a special coolant dye to the system, put some good mileage on the car, and start exploring the engine bay / underside with a UV light.
