ALL the fluid changes possible
I am going to change all the fluids this upcoming Spring for my 2012 C63 with LSD! Just wanted to get another set of eyes, am I missing anything else from the below?
-Oil (obviously)
-Coolant
-Transmission
-Brake Fluid
-Differential
-Power Steering
-There's no 'transfer case fluid' right? That's just the Transmission fluid?
Thanks!!
-Oil (obviously)
-Coolant
-Transmission
-Brake Fluid
-Differential
-Power Steering
Thanks!!
My valve cover gaskets are leaking so do you think I should just get new valve covers as well since I am in there? My car has 88k miles now..
https://mbworld.org/forums/c63-amg-w...placement.html
Step 1: Drill a large hole in the bottom of the turn signal to let the old fluid out. Step 2: Roll car onto roof, and then refill turn signal. Step 3: plug hole in turn signal with some JB Weld allow to cure for 2 weeks. Step 4: roll car back over and immediately try to start the engine while turning the headlights on and off very fast for 30 seconds straight.
This only works with Mercedes too, BMW's you can't change the fluid at all as it's a welded shut unit and this is why when it runs out those cars are basically worthless also why you see such low re-sale value on them.
