What is this ticking sound from under my car???
After the rebuild the engine oil was a bit too high (found out as it was burning oil in the dyno, right after a rebuild). Have barely driven the car since then, however its now making a ticking sound regardless of whether it is a cold start/warm start and seems to follow rpm
What do you guys think the sound may be due to?
Possible options in my head: exhaust leak, lifter tick due to aeration of oil, damage to bottom end??
any advice and opinions welcome!
link: https://youtu.be/CMYYMwyJjz0?si=chdk8vLZCcF7gYO3
As for the bottom end, it should be fine. An extra litre shouldn’t have caused enough pressure to damage the crank, or force a bearing into an unseated position, but dyno pulls are no joke…
These are relatively strong engines, the ticking is probably just an exhaust leak and the blue smoke on the dyno pulls was probably from having too much oil pressure and some was sneaking past the valve seals.
cars booked for the 7th so will find out soon hopefully!
