C63 AMG (W204) 2008 - 2015
Tail light problem
Old Jan 3, 2026 | 08:39 PM
RSI1968's Avatar
C63 Coupe C204
Tail light problem
Normally the left and right tail lights when switched on should have two horizontal red bar being lit up. Yesterday I noted the left tail light's lower bar was off, leaving only the upper one on. I replaced all three bulbs and cleaned the brown negative wire connection. It stayed off. It is not an LED assembly with only three 21w bulbs. I scanned for fault codes and couldn't find any. I would appreciate any advice. Thank you.
The left assembly only showing only one bar. The lower one bar is off.
The left assembly showing only one bar. The lower one bar is off.
The right assembly showing two bars.
