C63 AMG (W204) 2008 - 2015
Has anyone measured the bearing clearance of M156?
Old Feb 21, 2026 | 01:56 AM
vasilyang's Avatar
w204 c63
My 2012 W204 C63 has accumulated 200,000 kilometers. Recently, the engine's operation has not been very satisfactory. I am planning to rebuild the engine but I noticed that the maintenance manual suggests configuring according to the letters on the crankshaft: R, Y, G, B, but it does not provide the exact range of bearing clearance.
Has anyone rebuild engine and measured the bearing clearance of M156?
Old Feb 21, 2026 | 10:44 AM
C63s_Jack's Avatar
AMG C63s Coupe
Is this your first engine rebuild ?
Old Feb 21, 2026 | 11:38 AM
vasilyang's Avatar
w204 c63
Yes, I will invite my technician friend to come along. It's just in the planning stage for now, hahaha. I'm afraid that after opening the engine, I'll find the small bearing is worn out and needs to be replaced. I saw someone post before that the crankshaft journal should be 70mm and the bearing clearance should be between 0.07mm and 0.09mm. I don't know if this data is correct.
Old Feb 21, 2026 | 01:46 PM
C63s_Jack's Avatar
AMG C63s Coupe
Originally Posted by vasilyang
I'm afraid …
I m too ! If you not know what you are doing.
You need absolutely the MB manual for rebuilt.
This is not a 1cyl
moped engine.
Watch YT shift 2 passion first for further education if you want to make a rebuild.
Best engine (AMG) guy i know (AMG engine rebuild only) .
Good luck.
Old Feb 21, 2026 | 06:03 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
This is not the engine for your first build. At all.
Old Feb 21, 2026 | 09:37 PM
roadtalontsi's Avatar
10 C six trizzle
The crank has letters and so does the block. It's not complicated but you need to read thoroughly. The factory WIS instructions do provide clearance information. It will cost you $1000 in 1 time use hardware if you want to test and disassemble only to verify amg knows what they are doing.
Old Feb 22, 2026 | 01:04 AM
C63s_Jack's Avatar
AMG C63s Coupe
All the tools and special tools you need … $$$
cleaning/washing all , make measurements etc.
And than (sometimes) there are things no manual (WIS) shows. Everyone who ever rebuilded an engine knows this.
Old Feb 22, 2026 | 09:50 AM
vasilyang's Avatar
w204 c63
Thank you all for your concern. However, I'm not doing this alone. Although it's just a plan, I still want to invite a friend with AMG experience to assist me!
Old Feb 22, 2026 | 09:53 AM
vasilyang's Avatar
w204 c63
1
Hello, friend. Is there any information about the clearance of the connecting rod bearing and the crankshaft bearing on WIS? If there is, could you please take a screenshot for me? I would be extremely grateful.​​​​​​​
Old Feb 22, 2026 | 11:13 AM
unless that friend has rebuilt an M156, it's the blind leading the blind. But keep us updated, my life is in shambles and I love sharing the misery. 😄😄
Old Feb 22, 2026 | 11:04 PM
vasilyang's Avatar
w204 c63
Hey, friend, don't be so down. Life is like our old engine. Though it has been through a lot, it will still run smoothly and healthily.
