C63/C63S AMG
Renntech Stage 1 Development/Dyno - 609.7 ps / 806 nm
Old Apr 18, 2015 | 11:00 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
Renntech testing their stage 1 M177 software just put down 602 HP and 595 ft-lb torque (609.7 ps / 806nm)
Old Apr 18, 2015 | 11:03 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
Dyno added of stock vs Renntech Stage 1:
Renntech Stage 1 Development/Dyno - 609.7 ps / 806 nm-0kxyzcw.jpg
Old Apr 18, 2015 | 11:49 AM
Iceman II's Avatar
2015 C63S / 2015 BMW M4
This is awesome stuff.....! Subscribed for sure.....!
Help me understand -- stock S model peaks at just below 500hp? Did I miss something here?
edit: Nevermind....figured it out.
Old Apr 18, 2015 | 01:02 PM
JPMBenz's Avatar
17 C63 S Coupe
So crazy! LOL
I think the License Plate is comical also! HAHA
Old Apr 19, 2015 | 11:14 PM
AV1's Avatar
AV1
C204 C250-CDI
And so it begins
Some of us did say long ago that those sorts of power levels would be easily achieved with just a simple tune alone.
Long term down the track serious tuning is going to net some whopping results, an AWD variant in future would be welcomed
Old Apr 19, 2015 | 11:17 PM
AMG Boost's Avatar
2010 C63 P30
Ya that must be at the crank, not at the wheels. Still very very impressive. 100hp gain from a tune. Jesus...
Old Apr 19, 2015 | 11:24 PM
Iceman II's Avatar
Its at the crank. Yes, good numbers.
Old Apr 19, 2015 | 11:28 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Originally Posted by AV1
And so it begins
Haha yep, back in October
"Tuners are probably already salivating over 100+hp ECU-only flashes"
Old Apr 20, 2015 | 11:22 AM
aznevoviii's Avatar
G63 AMG
So c63 tuned vs c63s tuned,
Whats the difference?
Old Apr 20, 2015 | 11:28 AM
JPMBenz's Avatar
17 C63 S Coupe
What did this car dyno to the wheels stock? 503??
Old Apr 20, 2015 | 12:17 PM
camnet's Avatar
2016 C63S, 2008 Ford FR500S, 2010 Porsche Panamera Turbo
I'm confused. Isn't the point of the dyno to measure the HP/Torque at the rear wheels which can then be extrapolated with driveline loss to arrive at a approximate crank HP ((I know it is when I have my mustang dyno'd)?
Old Apr 20, 2015 | 12:28 PM
Arcoril's Avatar
991 C2S, AP2 S2000, E400 Coupe
This is from an engine dyno. It's much more accurate than having to estimate the drivetrain losses when you're measuring at the wheels.
Old Apr 20, 2015 | 12:36 PM
camnet's Avatar
thanks. That makes sense. Where's the sheet from the chassis dyno in the OP's video?
Old Apr 20, 2015 | 01:03 PM
PetroC63's Avatar
2012 CTS-V
Usually that's the case.
This particular car(non S model) made 433 rwhp before tuning and 534 rwhp after tuning. Which means these cars are underrated from the factory.
Old Apr 20, 2015 | 01:10 PM
camnet's Avatar
Thank you much. Can't wait to get my hands on my car!
Old Apr 20, 2015 | 06:46 PM
sinurgy's Avatar
Reebok
I don't understand, the video shows the car rolling on drums, how is that not measuring rwhp? I mean based on the numbers (600hp) I don't see how the hell it's not crank but my understanding is that getting true crank numbers is extremely expensive because you'd need to remove the engine. What am I missing?
Old Apr 20, 2015 | 08:00 PM
Iceman II's Avatar
The video says it is a "S" model. The badge has been removed but the video title says C63 S.
Old Apr 20, 2015 | 08:05 PM
Iceman II's Avatar
Are you saying this graph is incorrectly labeled and should be WHP versus BHP? That would make more sense (hopeful and wishing) as it would then show the engine is underrated. At this point, the current dyno just confirms that MB is very accurate with their rating of the engine. The black line (stock) shows its exactly as advertise.
Old Apr 20, 2015 | 08:35 PM
Iceman II's Avatar
CORRECTION: Getting word that this is the non-S model. If confirmed, that surely changes how I view the graph. That means the C63 non-S model is pulling over 500 stock and a simple ECU tune places this near 600+.
Old Apr 20, 2015 | 08:45 PM
sinurgy's Avatar
Reebok
No I'm saying that none of this makes sense and I'm hoping someone who knows more than me about this stuff can shed some light on it.
Typically if you put a car on a dyno machine, which this seems to be since the car is sitting on rollers, the output that is measured is indeed rwhp but no way in hell this thing is putting down 600rwhp with just a tune (unless they just cranked up the PSI of the turbos, engine be damned)! So that leaves me with questions...what exactly is happening here?
My best guess is this...they know the car is supposed have X amount of HP from the factory so they run it on the dyno before any mods are done to get a corresponding baseline RWHP. Then they use those two numbers (factory reported HP and their baseline RWHP) to calculate the drivetrain loss. Once they have the drivetrain loss figure, they can guesstimate crank HP on any dyno run they do. Now why you'd do this instead of just using RWHP is beyond me but that's my best guess as to what they're doing.
Old Apr 20, 2015 | 09:00 PM
EkS's Avatar
EkS
C63
Power and torque (in Nm) at CRANK.
STOCK 433whp on C63 non S model ...
534whp for STAGE1
This is from their YouTube channel.
Old Apr 20, 2015 | 09:22 PM
sinurgy's Avatar
Reebok
Ok so it would seem my guess was right, they took a baseline, compared it to factory and calculated drivetrain loss. Now they simply apply that calculated drivetrain loss figure to subsequent dyno runs in order to come up with a guesstimated crank HP. Nothing wrong with that at all, it just confusing there for a bit.
So next discussion...what are they doing? Are they simply upping the boost?
Old Apr 20, 2015 | 09:40 PM
jamesyot's Avatar
03 Lexus IS300 (old faithful) / 91 3000GT VR-4 / 14 CLA45 AMG / 11 BMW X6M
damn I love my CLA buttttt
Old Apr 20, 2015 | 10:44 PM
AV1's Avatar
AV1
C204 C250-CDI
AFAIK the M177 engine in both the S and non S is the same hardware spec running different software spec tunes.
If that is the case then you'll be able to get the same output for either one with a software change.
Old Apr 20, 2015 | 10:55 PM
amanuuh's Avatar
2014 CLA 45AMG , 2015 C63 (W205)
damn the fact that this is only the C63 is getting me excited lol
