C63/C63S AMG
C63 vs Upcoming BMW M2 Coupe
Old May 1, 2015 | 04:29 PM
RPM99's Avatar
2012 Mercedes C350 Coupe
Trying to decide between c63 and BMW M2 coupe.
What to do? C63 is more powerful but will it be more fun to drive? Fun factor is key. Wish I had the $$$ to buy both...
Old May 1, 2015 | 05:02 PM
amanuuh's Avatar
2014 CLA 45AMG , 2015 C63 (W205)
I feel like M2 is going to be really similar to the CLA but a bit better. I think the C63 is going to be better. If youre gonna track id say get the M2.
Old May 1, 2015 | 05:27 PM
RPM99's Avatar
Definitely not going to track it. Streets and highways only. Looks like c63 is in a higher class than m2. Plus m2 looks to be very small.
Old May 1, 2015 | 05:28 PM
Iceman II's Avatar
2015 C63S / 2015 BMW M4
I always recommend asking this question first -- it generally will lead you to one path or the other. Chassis with power or luxury, raw sound, and pure muscle. If you're a track guy...why not go M4?
Old May 1, 2015 | 05:45 PM
amanuuh's Avatar
Seems like you've already made up your mind lol
Old May 1, 2015 | 07:07 PM
RPM99's Avatar
Yes thanks for your help Amanuuh. Your m2 to CLA 45 comparison makes sense. C63 is in higher class with m3/m4. Thanks for the clarification.
Old May 1, 2015 | 08:45 PM
zibby43's Avatar
'20 GLC300 SUV
As others have said, most will not be cross-shopping the M2 with the W205 C63. The C63 is a much bigger car. It's also faster and much more expensive.
If you're looking for a luxurious daily driver that has mega performance, you will not be disappointed with the W205 C63.
You'll need to drive it first.
Old May 4, 2015 | 03:49 AM
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
Plus the M2 will be coming with the same N55 motor as the M135i and M235i
So straight line you will get a slightly tweaked M135i keeping up with you
Old May 4, 2015 | 11:41 PM
AV1's Avatar
AV1
C204 C250-CDI
As above should be comparing apples with apples
However I agree with your wanting both as they will be quite different, both a C63 and a M2 in the garage would be nice especially if your opting for the W205 sedan C63, not really much point if it's a C205 C63 & M2 combination though.
On this whole M2 thing I believe it will cause more of a problem for its bigger brother sibling the M4 than AMG models, BMW would have to purposely down grade it to make sure it doesn't come close to the M4, however I'm confident that down the track tuned M2's will be impressive enough to beat a M4 in many regards, it was a similar story with previous iterations of the 135i family with the culminating M135i really making a big statement and being better than the same generation M3 in some regards.
Also there have been numerous comparisons of the CLA45 vs the M235i and the M235i seems to mostly come out on top, that being the case the M2 should be convincingly better than the CLA45 - interesting comparison to look forward to and then how AMG respond to make the future CLA better.
