Throttle tip in hesitation?
Correct, as I've stated in a previous post I too have a TCU tune on my 7GTronic and it's not entirely but almost cleared this problem certainly much better than stock setting, mine is not from that company nominated above though there are now numerous people doing it pretty much all who do ECU tunes now also have TCU tunes
It does seem to be related to tune rather than built in, for anyone who's driven any vehicle equipped with the ZF brand of auto transmissions which are also of regular stall converter type they do not have this problem what so ever.
As for DSG's they too suffer from hesitation in certain situations but it's different and not as bad as our MB transmissions.
The DSG in my S4 is super responsive and is a blast to use. Took 59000 miles of abuse and didn't hiccup once. Stock S4 output of 333HP up to around the 550HP approx (estimated), the car has now.
As stated, the TCU flash only made it that much better.
There are supposedly a couple of TSB's that seem fix the issue to some degree (if you say the right words to get the dealer to install them), but I don't think it completely goes away.
Anytime this has happened to me, it's when the car is in between first and second gear and hasn't downshifted yet. I drive the car around in manual mode 99.9% of the time, so I'm not as familiar with the characteristics of the auto mode.
It seems to happen under two different scenarios (both involve quick stop-and-go, stop sign-type situations):
- I don't come to a complete stop (barely rolling though) and then try to go. The hesitation seems to be the lag time for it to get into 1st gear. I'm asking it to go when the clutch is disengaged, and the TCU is trying to figure out what to do.
- I've come to a stop before the car has begun shifting out of 2nd gear, and when I press the throttle quickly it aborts the downshift, tries to get off the line in 2nd, and then downshifts to 1st after a couple seconds. It's almost like the TCU aborted the 2-1 downshift so I can get immediate power and then downshifts a few seconds later when I'm off the line.
Either way, I've learned to live with and get around this idiosyncrasy to the point I don't even notice. Just anticipate your shifts like you were driving a manual transmission, and the issues go away.
I do note JPBenz' suggestion of actually downshifting in C to force a drop to 1st...that is an answer that, while not ideal, is tolerable.
I must admit this sounds like something MB could/should address with software.
other this this little wrinkle, love the car (having said this, if i could swap in my NA 6.3 from my '12 it'd do it in a heartbeat!)
This trans is just a 7G auto with the fluid coupling tossed and a multi plate wet clutch in its place. After the car is moving well it is essentially the same as the auto with the fluid coupling locked and all the shifting done inside the trans with the clutch packs. Just soft wear tuning from here out. The hard part for AMG I would guess is the many different loads and situations in comfort at slow speeds. The trans starts in 2nd in C and coasts in C so there are some more considerations here.
I'm almost always in Manual mode in either S+ or Race drivetrain settings (both used through the Individual setting), and the transmission does the same thing for me. It is not a Comfort only issue.
That being said, if you're calling for throttle when the clutch is disengaged, what do you expect the car to do? Dump the clutch? Just learn not to jump in front of traffic when you aren't in the correct gear (which is something you should do anyway).
It is probably a trans internal hesitation in the several clutch packs (opening and closing to get the appropriate gear) and not the one that replaces the fluid coupling.
This is most likely a soft wear issue and can be remedied.
Have you had the new transmission update that has fixed many issues for some?
I don't have 1000 miles on yet but have not experienced this on my 2016.
Does not happen if I come to a complete stop. Only when I slow down for a turn, then try to accelerate into traffic.... the car is just not ready to go or accept my throttle input "YET"....
I'm not saying someone doesn't know how to drive if they are experiencing these problems; I'm just saying this transmission works significantly better if it's driven with the mindset of a manual instead of a slushbox automatic. It's a car issue, not a driver issue.
I wouldn't head to the dealer just yet though - I spoke with the AMG sales guy, who in turn spoke with the shop foreman, and they could not find any transmission bullet, update or the like... I'm going to take it in one weekend though for them to try and resolve the issue. In the meantime, there's no "official" fix.
By the way, I also inquired about a "software fix" when I got my rear axle oil change and was told no software upgrade or fix exist.
