C63/C63S AMG
Drove the Eurocharged tuned C63S, Holy Hell!!
Old Jul 7, 2015 | 12:06 PM
  #51
ML63 AMG's Avatar
CL63 AMG
Originally Posted by FastLaneJB
That makes sense. Chris Harris mentioned in his review of the C63S that the engine is built to take almost diesel like pressures which is unheard of in a petrol engine. So fully understand the engine is extremely strong.
I suspect this is all because they'll use this engine across the board in the future and in cars with more bhp than the C63S. Not putting better turbos for this model is simply because they don't need to for the power outputs they are selling it at but the engine is the same to cut R&D costs I imagine.
I take it this tune won't over cook the turbos or that's a possibility?
No, the tune is still very conservative even at those power levels. Yes, running smaller turbos is a natural barrier /limit to help prevent engine damage hence why it's virtually impossible to blow the motor on stock turbos
Old Jul 7, 2015 | 12:10 PM
  #52
ML63 AMG's Avatar
CL63 AMG
Originally Posted by msd3075
What about other driveline components (transmission, diff, halfshafts, etc.)? Are those just as over-engineered?
You're only as strong as the weakest link in the chain.
The C63s will actually be able to handle much more power than the GTS because of its MCT transmission vs. the DCT in the GTS. For that reason you will actually see the higher numbers in the C63 platform as tuners start going crazy.
Nobody knows the real limitations on the half shafts or the differential, but I would assume 700hp is probably a safe number.
Old Jul 7, 2015 | 01:42 PM
  #53
betrezra's Avatar
C63 507 AMG DA Car #19
"Nobody knows the real limitations on the half shafts or the differential, but I would assume 700hp is probably a safe number."....... and we know from watching the cutting edge record holders for 1/4 mile MB runs..... these parts can be upgraded if necessary.
I see a 9 second c63S in the future from one of the all-out guys.... after this platform has depreciated enough to justify mod to the xtreme for little entry fee, and after there are some good used sources for these motors. Some will undoubtly get popped with extreme boost/tunes/AFR's....... chasing ET/MPH.
Old Jul 18, 2015 | 06:18 PM
  #54
CAracer's Avatar
GTS AMG
Originally Posted by JPMBenz
I will be doing my 1/4 mile shortly...
Just wondering if you had a chance to run the 1/4 mile yet? If so, what were your times?
Did you get the Eurocharded tune? If so, how much faster does your car seem? I was there today and talked with them. Jerry was in Mexico.
Old Jul 20, 2015 | 10:26 AM
  #55
JPMBenz's Avatar
17 C63 S Coupe
No I have not. I meant this coming Wednesday; if I can get there. No, I do not have any tunes at all. I don't play on any tunes at this time.
Old Jul 28, 2015 | 03:43 AM
  #56
Mode Carbon's Avatar
SPONSOR
E90 M3, F80 M3, C63 507, F90 M5
Eurocharged ftw
Old Jul 28, 2015 | 07:37 AM
  #57
deutschlandFan's Avatar
4Runner Trail, C63P Edition 1
Saw a dyno sheet on "the other site" damn Eurocharged made something like 535hp/630 torque.
Bananas lol
Old Jul 28, 2015 | 04:30 PM
  #58
ML63 AMG's Avatar
CL63 AMG
Well of course anything can be upgraded. I was merely stating on stock components 700 is a safe estimate. Torque is more important than HP bc torque is the actual low end to mid range twisting force where the strain is highest on the drive train components. At higher rpms the strain is less bc the car is already rolling quickly and has momentum. Putting super stick tires (like drag radials), also increases the odds of breaking shafts.
Old Jul 29, 2015 | 06:36 PM
  #59
spacegeek's Avatar
Currently Looking
Bananas lol
The other site?
630 torque is crazy and will eat some tires. You might have to change them out every 5000 miles.
Old Jul 29, 2015 | 08:21 PM
  #60
Eurocharge
Old Jul 29, 2015 | 08:41 PM
  #61
betrezra's Avatar
I'll be curious to see some 1/4 mile times with the tune and d/r's.
Old Jul 29, 2015 | 08:59 PM
  #62
jamesyot's Avatar
03 Lexus IS300 (old faithful) / 91 3000GT VR-4 / 14 CLA45 AMG / 11 BMW X6M
Ill have this in 2 weeks! Hyped
Old Jul 30, 2015 | 03:11 AM
  #63
AV1's Avatar
AV1
C204 C250-CDI
Yes, also looking forward to some instrumented run times etc.
All these tunes coming are very exciting but every ones waiting to see the real World results
Old Aug 4, 2015 | 12:10 PM
  #64
ML63 AMG's Avatar
CL63 AMG
The eurocharged tune is absolutely nuts. I would never want more than a stage 1 to be honest. I would the only focus on ways to keep TQ he same but upgrade HP at higher RPMs (downpipes etc)
Old Aug 5, 2015 | 01:22 AM
  #65
Jones2012S4's Avatar
2012 Audi S4
I want the tunes to be at APR RS7 levels! Push a little more :-)
Old Aug 5, 2015 | 04:14 AM
  #66
AV1's Avatar
AV1
C204 C250-CDI
Never been tempted for an extra 30 - 40hp some ECU tunes give you but wow... 150+ HP.
That's a typical advantage/benefit of Forced Induction vs N/A
Look at the power and torque output of the little M133
Even MB's little 4 pot TT FI diesels can put out more torque than the mighty and massive displacement M156.
FI is the way forward
Old Aug 5, 2015 | 05:22 AM
  #67
FastLaneJB's Avatar
335d xDrive, C63S on order
I've not had a N/A car for 10+ years but even with turbo based cars that's quite an increase vs stock.
Always amuses me when people talk about turbo lag. 10 years ago there was turbo lag and you could feel exactly where it kicks in. These days it's all but unnoticeable as its so quick.
I had a car where the turbo kicked in around 1,800 rpm back in the days. If you came off the line without the turbo spinning a granny would beat you off the lights. If you revved enough to spin the turbo you'd wheel spin off the lights. There just wasn't anything in between snail slow and hoon
It'll be why the car pulls off the line in 2nd when in comfort. 1st is for when your towing a tank which has its brakes on
Old Aug 5, 2015 | 11:29 PM
  #68
AV1's Avatar
AV1
C204 C250-CDI
I hear you and can relate to the above I still own an 'older tech' turbo petrol car and totally love and/or accept the way the turbo power curve comes in from initial lag to eventually going like a skinned cat lol, it makes for a fun full ride experience IMO
Having said that I'm totally looking forward to owning one of the newer tech petrols such as this M177 for hardly any lag at all, I'm already used to that with my C204 twin turbo CDI coupe, whether stock or tuned like mine they (the diesels) have almost zero lag and pretty much 100% torque at WOT almost immediately off idle, the only lag or hesitation is in the damn transmissions LOL
