KM C63s ED1 Build
Just spend the last hour on Tire Rack comparing every tire and the difference in width between the 275 and 265 is just about nothing on the AMG wheels, except the price I guess.
285's though would make a big difference. I will have to wait and see who decides to try 285's first and go from there.
I can't seem to find what the wheel width's are. I am assuming 8.5 and 9.5
4Runner Trail, C63P Edition 1
Exactly! There is barely a diff between 265 and 275.
I think the best bet for factory rims are 255/35 and 285/30.
ETA the new coupe spy thread is spotted with ^ those ^ same size Conti Sport contacts
C63S ED1
I have the same problem as Aman with the fronts I'm 12MM short,I'm even worst off I'm 12MM to wide in the rear they are making a whole new set of Rims ****!!!!
http://www.tirerack.com/tires/tires....n&autoModClar=
#34
C63S ED1
#35
#36
That makes sense there is more traction. Glad to know we can run a 285 at the rear. What did you run in the front?
#37
Mercedes-Benz 2016 C63S
I'm also keen to hear the response from JPMBenz's question regarding what width and profile you went with in the front? 265's?
#38
#39
Rear 10.5" x 20" 285/30/20
40 wouldnt make sense...
the original specs dont even come in 40
#40
C63S ED1
#42
Yeah my rears came out perfect. I need 3mm more in the front. Mine looked bad cause the stretched tires. They fit really nice now. I'm getting. I personally think you should go with a darker rim only because the car looks to silver but other than that it's a sick set up. It's going to look sick dropped.
#43
C63S ED1
#45
C63S ED1
#48
C63S ED1
#49
I wouldn't want to go any lower a profile than 35 tbh - not for some of our roads around where I live...
Based on the 20" rims and wheel specs above, I'll assume 285/35/19's is going to be no problem in the rear then. Also hoping 265/35/19s in the front will not be an issue. I'll have this all checked out though once I get the car.
@Kingmonkey - car looks awesome dude. Ring its neck!
