More Dyno results...
Unfortunately, we could not get an ignition pulse so we could not get a proper rpm reading for the torque calculation. I'd like to say thanks to Renntech florida for calling my back and helping me out, but it still wouldn't work for us!!!
It was a bit of a cold day up here, and we are at a higher elevation than sea level in Alberta, Canada. But the results were great! I've attached a picture while waiting for the shop to send me the files.
Did a three pulls, one in race, one in Sport+ and one in comfort... was just curious to see if I would get a different result (the car is stock at the moment). Looks like the race mode gave me the biggest numbers @ 515WHP! Although, I do hear that dynojets read a bit higher...
For a comparison, my friend ran his M3 and i will post his results shortly. With his tune and downpipes he made 472hp.
Your results above confirm what some other tuners have also stated in that a stock AMG M177 is a lot more powerful than a tuned BMW S55
Seriously no offense to the BMW community but these new M's sound so terrible it's shocking to the ears, that one on the dyno sounded like my old washing machine on the spin dry cycle ie. totally revolting
By comparison the AMG sounds so good anyone could watch and listen to that all day long over over again
When I drive the car, it does seem to have a little more jam in race mode than all other modes... I did have the car switch into dynomometer mode as well.
I will have to ask the AMG technician about the ignition pulse wire next time I bring the car in for service and maybe go for another couple pulls.
A Dynojet to Mustang Dyno can vary 10%-12% higher. Meaning on a Mustang Dyno you could would put out about 452 RWHP. Now, we have seen cars on here, put out 480 RWHP. What octane fuel were you running?
It's a dyno queen trick I used back in the day to exaggerate how much hp I could make tuning turbo Hondas here.
Ask AG Haute to print out the uncorrected data for both cars and you'll have a better idea of what power the car is putting down at the wheels compared to others that don't use this trick.
the tuning industry is a sketchy one.... no time slips no proof of anything these days.
Thanks for sharing what I already suspected about tuners.
Maybe I'll show some naivety here to practical application vs academia theory, but does the ECU calculate boost off of gauge or absolute pressure?
If it's absolute pressure, I can see where you are going. But if it's based on gauge pressure (Gauge = Absolute - Atmospheric), the turbo/ECU wouldn't know anything is different and would just be adding the same amount of boost/pressure regardless of what the atmospheric pressure is.
Use the air pressure in your tire as an example. What you are measuring in gauge pressure, not the actual ("absolute") pressure of the air inside the tire. You measure the air pressure, and the gauge tells you it is 35 psi. Assuming standard conditions (sea level, 77 degrees F), atmospheric pressure outside the tire is 14.7 psi. That means the absolute pressure inside the tire is 49.7 psi (35 + 14.7). In other words, there is 49.7 psi pushing on the inside of the tire and 14.7 psi pushing on the outside of the tire. The net result (gauge pressure) is a 35 psi outward pressure.
Same thing applies to forced induction on your engine. Boost is usually quoted in terms of gauge pressure, so say an engine is running 12 psi of boost. That means the gauge pressure of the intake air is 12 psi, but the absolute pressure on the air is that plus atmospheric pressure (12 psi + 14.7 psi = 26.7 psi).
Which of these pressures is the ECU measuring?
If it's absolute, your intake air pressure would be identical regardless of altitude because the ECU would replace the difference in atmospheric pressure with more gauge pressure (boost). No correction would be needed for altitude and I could see how you'd get a gain from then adding a correction on top of that.
If it's gauge pressure (as every engine seems to be quoted as using in terms of boost), you really aren't gaining anything. Maybe a slight advantage because the boost added is a slightly higher percentage of the atmospheric pressure, but other than that it's prettty much a wash.
Last edited by msd3075; Aug 25, 2015 at 10:34 AM. Reason: Can't add two numbers correctly.....
The same principle applies with cars. That is why turbo charged cars perform much better at high altitudes than NA cars.
There are limits on how much a given turbo can compress the ambient air so even turbo vehicles suffer some performance loss at higher altitudes. However, the intake system is measuring the amount of oxygen going into the engine, so it can match that with the proper amount of fuel. At higher altitudes, where oxygen density is lower, the turbos will work harder and will, up to their design limits, provide the same amount of oxygen to the engine as at sea level.
Trust me, I'm a BSME by degree that knows plenty about the (theoretical) inner workings of forced induction works. You don't want me pulling out the old P-V diagrams from old (and probably outdated) textbooks to put you to sleep with lengthy explanations.....
If that's the case about how the engine supplies boost, it means boost isn't fixed and is then variable based upon altitude. It's make sense then that you'd see little-to-no difference in engine performance due to altitude. I guess I just always assumed boost was a fixed 'gauge pressure' measurement of the increase in intake pressure over atmospheric pressure.
And also only for ideal gases. But that's a different topic all together. Please, please, please don't make me pull out my enthalpy tables and start interpolating.......
With that being said, and I brought it up earlier, it all depends on the size of the turbo. By the time you get to higher elevations such as Colorado, turbo cars will lose power compared to sea level because it's well past the turbo's limits and can't compress that thin air to the absolute pressure at sea level, but it will still have a huge advantage over an NA engine.
This is also the reason why chip tuning is less effective at altitude. They're generally tuned to maximize what the turbo can push out at sea level, so even going up to 3700ft here it's out of breath and won't gain much over stock.
So at sealevel a turbo will generate more boost than at 4000' altitude (all things being equal).
If the ecu controls a blow-off valve, to keep boost below 17psi.... and if the turbo have the excess capacity, then by use of the BOV the ECU can maintain the same 17psi peak boost even at higher elevation.
All speculation since we don't know the architecture of the c63s .... yet.
oh yeah BSME here too. THE engineering degree to get. IMHO.
BSME '06 here. Showing my age, or lack thereof.
All this talk about boost pressures made me want to pull out my old Thermodynamics and Thermo-Fluid Systems textbooks. Made me want to refresh on everything I hadn't looked at in a while. Until I realized I sold all my books back to the book store for beer money....
But for clarity / summarize, I think almost all of you guys are saying the same thing... Almost.
Ultimately a turbocharger is just a centrifugal compressor... There really should not be much change at various altitudes (hence the airplane analogy above), the turbo will always boost to get to a set pressure as called for by the ECU (in gauge). The ECU should always be calling for a consistent pressure (for the most part).
The only time there will be an impact at a higher altitude is if the turbo charger (compressor) is not able to "work" hard enough to generate the amount of pressure the ecu is calling for, meaning you will lose boost and power.
The SAE correction uses a 15% mechanical efficiency factor which really should only pertain to Naturally Aspirated motors. Which is why the readings are so high... The uncorrected numbers are probably more reflective of what the actual power is... I will ask for the uncorrected number. I have a hunch it will be around 480hp.
Naturally aspirated engines because of no compression will see a loss in power because they only see atmospheric pressure... so the density of the air being fed into the motor is lower. Less air density, different air/fuel and less power.
For the engineers - turbo cars at high altitude, low rpm performance, at least until maximum absolute pressure, suffers from the same power loss as an NA motor. So while we have the same peak power as sea level here, our low rpm performance is quite poor, resulting in a narrower powerband. The knock on effect is that launch control, which is typically setup for sea level powerband, isn't optimal here and we "bog" off the line.
In a couple of years, when AMG starts using hybrid power trains, the electric motors should be able to fill in that gap like in the latest hypercars such as the P1.
1. More Boost... to a limit.... you can get out of the eff range of the compressor, OR get too much boost and have pre-ignition... or too much power and split the block or crank.
2. Less Fuel Lean it out.....to a point. We used to tgt AFR of 12.2-12.8 at WOT under full boost in 3rd gear pulls to be safe. There is power above 12.8 AFR.... but how safe?
3. More timing...... to a point.
ALL THREE!
At higher elevation you have less oxygen, and less ambient pressure.... so turbo can try to comprensate for this lack of pressure/O2.
A belt driven centri blower has a fixed step up in boost as related to rpms........ I have some experience playing with reducing inlet restriction of a vortech on a V8..... you can gain 1-3 psi of add'l boost on the outlet of the cent blower JUST by adding a less res power inlet pipe in the fender. I presume this works the same on a turbo car.
The part I'm not totally clear on with the turbo..... is if the exhaust heat/rate of flow affects the rate of boost...... and if this affect changes with elevation.
I'm guessing that part is negiligible.... and the ECU controls boost simply by opening/closing a Waste-Gate valve...... and ECU keeps max boost per a map.... and just dumps extra boost to keep everything happy.
I suspect we will see some DRAMATICALLY improved ET's/Traps/dyno numbers in 30-40deg F weather.......... as you will get all three above:::::: more boost, more O2, more timing (since ecu will not have to pull timing due to HOT air).
Hope all makes sense......
and btw..... did not mean to sound cheaky about BSME being THE degree..... perhaps a bit biased.
I'm a bsme in the oil field. Class of 91.. so old old guy here. Will be 47 in sept! Mid-life crisis time!
Actually sitting in my hotel room in the middle a damn oil field as we speak. Seminole, TX is such a happenin' place......
Wait for the downshifts
after that result.
