Why is Coupe So Much More Agressive Looking Than Sedan??
IMHO coupes almost always look better than sedans of the same car type regardless of big or small changes to the sheet metal, the sleeker lower silhouette lines alone makes a huge difference
Always a case of each to their own sedan/estate if you must, coupe for everybody else
The Black Series will be a monster, cannot wait to see it and its specs
IMHO a direct front on view of the W205 C63 is its best angle, the new C205 C63 absolutely trumps it from the same frontal aspect, it's not just the wider fenders and flares it's also the lower roof line and it also looks fantastic from every other aspect view point, the same cannot be said of the sedan IMO.
In real life the differences will be even more obvious and very easy for someone with a knowing eye to tell apart if you had either one of these in your rear view
