C63/C63S AMG
Renntech C63 biturbo 800+hp
Old Oct 3, 2015 | 05:43 AM
lorie's Avatar
E55 K
http://www.boostaddict.com/content.p...o-R800-package
Old Oct 3, 2015 | 07:10 AM
Will617's Avatar
2016 C63S
800 hp is nuts. 1/4 mile times should be impressive but how about drivability and traction? In stock form this car already has a lot of wheelspin.
Old Oct 3, 2015 | 11:00 AM
betrezra's Avatar
C63 507 AMG DA Car #19
Low 10's high 9's w traction
Old Oct 3, 2015 | 12:08 PM
PeterUbers's Avatar
Still waiting for a stock c63s with rear slicks to run the 1/4....
Old Oct 3, 2015 | 12:16 PM
JPMBenz's Avatar
17 C63 S Coupe
$20,000 later...LOL
Old Oct 4, 2015 | 07:16 PM
mr747's Avatar
c63
thats massive power but the auto wouldnt last 1 week at that power level
Old Oct 5, 2015 | 12:28 PM
RENNtech EUROPE's Avatar
AMG
Thanks for sharing, this was just meant to be a sneak preview, so no FINAL (technical) details or pricing available yet.
It's not a final product release.
1. Car was / is run on PUMP FUEL which we get at the well known local Nuerburgring Gas station, 98 Octane RON (equivalent to 93 AKI). This station is just 200 meters away from our facility http://www.doettinger-hoehe.de/
2. Transmission is the well known MCT, this is stable as we all know, however it needs a reflash to hold the torque as the pressure on the clutch is not high enough from factory due to the fact that it is (electronically) prepared to only hold up to 700Nm stock while combined with the M157 the basically same hardware comes with 900Nm stock and i.e. in a heavy S Class already.
The transmission is a 722930 K 7 C 1000 type (which means the hardware can take 1000Nm)
3. Forged internals: in the make but nothing more we would say yet at his point.
4. Losses: Depending on the setup, tires and so far with this car and the bigger tires we usually see around 70hp losses (approx 12-13%) on the SuperFlow 880 AWD during a stock run in 4th gear and around 100hp losses (approx 15%) at this power level. PS and Nm at CRANK are EWG/ECE corrected, in that specific case with a correction factor of 0.98.
Attached Thumbnails Renntech C63 biturbo 800+hp-2.jpg   Renntech C63 biturbo 800+hp-4.jpg   Renntech C63 biturbo 800+hp-5.jpg   Renntech C63 biturbo 800+hp-3.jpg   Renntech C63 biturbo 800+hp-1.jpg
Old Oct 5, 2015 | 12:30 PM
AMG
Turbos are good for up to 850hp but we are moving step by step now...
Attached Thumbnails Renntech C63 biturbo 800+hp-c63bt-renntech-r800-ps-tq.jpg   Renntech C63 biturbo 800+hp-c63bt-renntech-r800-whp.jpg
Old Oct 5, 2015 | 01:07 PM
betrezra's Avatar
BEAST!
Old Oct 5, 2015 | 03:41 PM
houstonT's Avatar
RENNTECH....when is a ECU flash going to be available?
Old Oct 5, 2015 | 03:48 PM
AMG
It is available, but not yet listed on the page, I guess in a week from now.
Old Oct 5, 2015 | 10:49 PM
princealidds's Avatar
2013 C63 AMG
What hp & torque do you see on a tune for the 2016 C amgS??
Old Oct 6, 2015 | 03:15 PM
AMG
Up to 625hp and 850Nm of torque (both at crank) on pump fuel, slightly more with Downpipes.
Old Oct 6, 2015 | 04:20 PM
irablumberg's Avatar
2015 C63S E1; 2016 C450 AMG
Can this tune be loaded using the OBDII port?
Old Oct 6, 2015 | 04:27 PM
AMG
No, the ECU needs to come out once, after that it can be flashed through the ECU connector.
If tuned once, it can be flashed through the engine bay connector afterwards.
OBD Flasher in the make but not ready to be released and no time frame here.
Old Oct 6, 2015 | 08:56 PM
CarHol's Avatar
MB
What consist of the Stage2+ turbos? Are they just wheel upgrades or completely new turbos?
Old Oct 6, 2015 | 09:55 PM
AV1's Avatar
AV1
C204 C250-CDI
Impressive !!! more than enough for most people's needs
This is what a lot of people will want, being it'll be available in future suits some of us just fine
Old Oct 7, 2015 | 03:02 AM
AMG
These are new turbos, but we are also offering a milder turbo upgrade which is good up to 700hp at crank.
Old Oct 15, 2015 | 12:54 PM
AMG
