C63/C63S AMG
Burmeister sound system in C Coupe. Terribly crappy?!
Old May 8, 2016 | 10:59 PM
AMG 17GT's Avatar
R Nine T
Originally Posted by HYPERTUNE
Burmester don't make loudspeaker drivers, so you shouldn't be surprised there are no Burmester drivers in the car
Really??
So exactly how was a buyer to know they were buying speaker grills ??!!
Old May 9, 2016 | 12:38 PM
ML63 AMG's Avatar
CL63 AMG
Is it possible to just upgrade the stock 8" superior ones in the same exact space?
Old May 9, 2016 | 07:53 PM
Gester's Avatar
W205 C63S
Guys - the including speakers are generally pretty good already. The really problem is the inability to adjust the EQ settings. That link before shows a way to remove all sound processing from the source and apply your own EQ map. It's tempting to give that a go
Currently the car also has different EQ settings for certain inputs and my iPhone sounds so much better via cable then just the radio.
Old May 10, 2016 | 12:28 AM
ML63 AMG's Avatar
CL63 AMG
Reason I ask is because GLC43 I am getting has roughly the same system but it's an open cabin trunk versus a small enclosed sedan so perhaps it will have a better sound system or sound dynamics.
Is it possible to run a small 8" on the rear of the car by the amp and runs custom side enclosure built in and run it off the factory amp?
Old May 10, 2016 | 12:33 AM
Gester's Avatar
W205 C63S
But thats the whole point, due to the compensation the system already makes to distribute the sound - it's not going to achieve a whole lot unless you can adjust the EQ yourself.
That blog posted earlier really explains it well - a full on all speaker replacement, down to just the sound processing replacement. https://w205audio.wordpress.com/
Old Aug 1, 2016 | 09:04 PM
happytorito's Avatar
06 Civic Si / 14 Jeep GC SRT / 16 C63s (Dead) / 17 C63s (Ordered)
I think that sound processing is a start but a subwoofer will be needed if you change the crossover points and use the footwell woofers as described in the link. Adding a powered sub or 2 should help in that department. I think it would be a nice project to redo the whole thing. Anyone knows the size of the speakers in the footwell? Are they 6" or 6.5"?
Old Aug 2, 2016 | 03:19 AM
  #32
grizzly111's Avatar
BMW
I tested the Burmester in a C63 wagon and it was quite honestly rubbish. Was expecting it to be passable (I alread knew that it was a weak point in the car) but it wasn't at this price point. It just sounded so thin and directional. Adjustments hardly made any difference. Hope Benz improve it. The W204 is defintely superior.
Old Aug 3, 2016 | 09:36 AM
  #33
Looks like the footwell speakers are 6.5". Maybe adding 1-2 powered subs under the seats will help.
Old Aug 3, 2016 | 11:22 AM
  #34
VaserC63S's Avatar
2015 Range Rover Sport Autobiography; 2019 AMG E63S; 2021 Range Rover HSE Westminister
Well I had 1700 watt 3D Signature Meridian in my 2014 RR Supercharged. It was out of this world good. Too bad car was lemon. I did a buy back and traded to 2015 RR autobiography that has 850 Watt Premium Meridian. I wished I had waited 3 months paid the $4500 premium to get another 3D signature. I thought the 850Watt systems not really that good.
Fast forward 2016 I get the C63S with Burmeister... I traded in my BMW 335 with an upgraded sound HK, too bad no choice with MB but to settle for average. Suddenly the 850Watt Premium Meeridian in my Rover doesnt sound bad at all. It sounds awesome! Its all relative. Once you sample something better then it sucks and it wont un-suck no matter what you do as you are already spoilt.
Old Aug 4, 2016 | 02:51 AM
  #35
ScottC63AMG's Avatar
2016 C63S AMG Estate
Added a sub to my estate, works a treat!
Burmeister sound system in C Coupe. Terribly crappy?!-amg-20sub_zpsppxorsxv.jpg
Old Aug 4, 2016 | 04:25 AM
  #36
kclman's Avatar
bmw m3
What sub is that?
Old Aug 4, 2016 | 07:42 AM
  #37
Toff's Avatar
C63s estate
Hi Scott
Can you please advise who did the install and a rough cost.
PM if you prefer
Old Aug 4, 2016 | 07:52 PM
  #38
Originally Posted by kclman
What sub is that?
It's a Kenwood 1400W Flat Sub - KFC-WPS1200F. Man does it sound awesome!
Old Aug 4, 2016 | 07:53 PM
  #39
Originally Posted by Toff
Hi Scott
PM if you prefer
I'm in Sydney so not much point telling you unless you are also in Sydney??
Old Aug 4, 2016 | 07:57 PM
  #40
Toff's Avatar
C63s estate
Hey Scott
Yes, I should have mentioned that I am in Sydney as well.....in the Burwood area.
Your setup looks very well made hence why I am also interested in getting something similar........and the fact that it sounds awesome is even better.
Old Aug 4, 2016 | 08:09 PM
  #41
kclman's Avatar
bmw m3
Thanks for that. Do you know how it connects to the cars system? Thanks
Old Aug 4, 2016 | 08:58 PM
  #42
Hey Scott
Hey mate, no worries! I got it installed by car audio place in Blacktown - http://xtremecaraudio.com.au/
It was just under $2k
Old Aug 4, 2016 | 09:18 PM
  #43
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Thanks for the share Scott!
Definitely interested as well, roughly how long did it take?
Did you have to leave the car there?
Old Aug 4, 2016 | 10:07 PM
  #44
Just so you guys know I have the wagon so not sure if under the shelf in the boot is exactly the same in the sedan/coupe?
I did need to leave my car there which wasn't the best but it took from Monday- Wednesday as they need to create a mold for the sub box and let it dry etc.
Old Aug 6, 2016 | 05:12 PM
  #45
m_coupe1999's Avatar
2012 Audi R8 V10 Spyder + 2010 Range Rover Sport Supercharged
My sister has a 2015 C250 with normal sound system, and my other sister has a 2016 C200 with Burmeister and believe it or not, the standard one sounded better to me. They are actually almost the same! I am 37 years old and still enjoy my loud music and i listen to all sorts of music from pop to hiphop to rock and even house music. The sound system in C class lacks bass which i feel is esential to any sound system. Even the bang and olufsen in my R8 is crap! No bass whatsoever, while many R8 owners praise it for clarity!
Bose in my 997 turbo is beyong great! And i remember having harmon kardon in previous cars and it was excellent too! So i dont see whats with recent cars putting stereos that are supposedly clear but have no bass! I cant imagine someone driving a C63 and listening to soft music hehehehe! Give me some bass!
Old Aug 8, 2016 | 02:03 AM
  #46
Mr. J's Avatar
C450, GLC43
Crutchfield has Focals on sale right now if anyone is looking to upgrade.
Also, Mike over on the W205 forum put together a solid thread on upgrading the Burmester.
Me, I'm OK with the Burmester. While it's not amazing, it sure is better than the POS that it replaced.
