C63/C63S AMG
WEISTEC VTA Valve(blow off) install
Old Aug 18, 2017 | 11:38 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Originally Posted by jjbradwell
Would this work on an M278? (2014 E550)
No they will not work.
Old Aug 18, 2017 | 11:40 AM
jjbradwell's Avatar
2014 E550 4Matic
Yea thought so.. thanks!
Old Jul 15, 2019 | 01:43 PM
nw66's Avatar
E63S 4MATIC 213
Think the E63S are different fitment from the C63S from what ive seen!
Old Jul 15, 2019 | 02:10 PM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
You do realize that this post was @ 2 years old :-)
Old Jul 15, 2019 | 03:00 PM
selenite_C63s's Avatar
2017 C63s AMG, 2020C300, 2011 G55 AMG
I see that Weistec says these do not void the factory warranty. Anyone have any experience with this?
Thinking about purchasing them.
B
Old Jul 15, 2019 | 03:10 PM
FLC63s's Avatar
swapping BOV's does not void the warranty...
I have RennTech BOV's on mine and the dealer never said a word to me...
Old Jul 15, 2019 | 03:19 PM
  #32
Thanks - looks like I may give them a try!
Old Jul 16, 2019 | 06:28 AM
  #33
nw66's Avatar
E63S 4MATIC 213
Old Feb 11, 2020 | 05:58 PM
  #34
illuzn's Avatar
'16 A45 '19 C63S Coupe
Sorry for resurrecting a graveyard thread but this is the first result on Google for an install guide (weistec doesn't give one).
I'm on a FL 19 Amg S and from the looks of it the clearance I have is far less than a pre-fl. Could have something to do with the new grill or something.
In any event, this is by no means a 10 minute install as promised on the package, it took me an hour but that was due to the difficulty in removing the bolts. The only way this is a 10 minute job is if you have the front end of the car off.
On mine there was no room for a ratchet wrench/ monkey wrench. In order to remove and insert the bolts I had to use vice grips on the torx bit itself to get a right angle to remove the bolts. One the head was exposed I then used a small string to ensure the bolt did not drop down into the engine bay.
You do not need to worry about the plastic bit falling off when the 2 screws are removed - it sits 1cm into the hole that it is mounted to and must be pulled forward first to come out.
From my experience, it is noticeably louder with the weistec "trumpet" install than with just the pipe removed. Could be in my head or maybe the angle in the oem part does something to the sound.
Also, you can 100% control this with your right foot. It isn't going to blow off in comfort mode unless you really want it to.
Finally, it is super loud... Like ridiculously, giggling inducing loud.
Edit: Also, I should not that in my FL. This reduces the frankly dangerous continuing acceleration on lifting off the throttle. Not sure if any one else experiences this but basically, on 50% throttle if I ease off the accelerator at the same time as the car changese gear (around 3k rpm), the car continues to accelerate. While this is somewhat expected because due to the nature of how a Automatic Transmission works, the vast majority of this was occurring due to the excess turbo charged air being recirculated into the intake manifold. One practical benefit of the VTA is that this effect is now minimal.
Old Feb 12, 2020 | 12:21 PM
  #35
nw66's Avatar
E63S 4MATIC 213
I think if your using a monkey wrench under the bonnet of any AMG maybe you should get someone else to fit them
Old Feb 12, 2020 | 03:10 PM
  #36
rbohgan's Avatar
c63s sedan
i just ordered the renntech BOV. need to install this weekend! thanks for video ill follow this
Old Feb 12, 2020 | 07:36 PM
  #37
illuzn's Avatar
Today I learned this means a completely different thing in the US.
Old Feb 12, 2020 | 08:51 PM
  #38
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
If your car is stock, the only thing you benefit from this mod is the great sound and cleaner intake.
Old Feb 20, 2020 | 12:30 AM
  #39
j.rol's Avatar
2016 Mercedes-Benz C63 AMG Sedan
if you can, would you be able to send a vid of how the renntech bov sounds please ? I’m stuck between getting renntech or weistec BOVs for my c63
Old Mar 6, 2020 | 06:53 AM
  #40
j.rol's Avatar
BOV renntechq
would you happen to have a video of the renntech BOV install ? I just got mines in and have no clue on installing them
Old Mar 6, 2020 | 07:08 AM
  #41
nw66's Avatar
E63S 4MATIC 213
top of thread mate! Piece of ****
Old Mar 6, 2020 | 09:54 AM
  #42
untamedd's Avatar
2019 AMG GT R
do you hear the sound every time you let off throttle? I have been a little weary of this mod or an after market intake because I dont want my car to sound like the japanese ricers that seem to always making that bov sound : /
is it a subtle mod or did you guys ever think it was obnoxious after getting it?
Old Mar 6, 2020 | 01:16 PM
  #43
nw66's Avatar
E63S 4MATIC 213
guessing you have an hot v yes they only hiss when you come off boost not when your flat out through gears! I can drive car in normal traffic without turbos spooling up so don’t get any sound! Driving with music on you can’t here it so nothing like and old Datsun GTR
Old Mar 30, 2020 | 12:28 AM
  #44
illuzn's Avatar
You aren't going to hear a thing as long as you are off boost. In order to get it to happen you have to want it to happen (but it does not require full throttle - anything above 3000RPM and more than 20% throttle application will generally cause it to occur). That said, always is relative... mine is making the noise 80% of the time because I drive it how it's meant to be driven and it brings a smile to my face.
Old Mar 31, 2020 | 03:07 PM
  #45
TeraPatrick's Avatar
C63 AMG
But can you hear it with a catless downpipes and a burble tune???
Old Dec 22, 2020 | 11:47 PM
  #46
ShaneN.'s Avatar
2018 e63s edition 1
I just watched the video, Im thinking of trying out what was suggested in the video to see if I like it. I think I found some caps on amazon to use. Are the ones weistec uses just vinyl? Just want to make sure what I find will hold up to under good temp.
Also, is there no hazard of having the lower section wide open for debris or whatever, whether it be with the weistec piece or if you leave the stock piece on but open (I get that, that isn't the intske side of motor going into the turbos).
1 inch cap :
Amazon Amazon
Old Dec 23, 2020 | 12:12 PM
  #47
nw66's Avatar
E63S 4MATIC 213
WTF you on about? What’s with the rubber end caps for from Amazon 🤷‍♂️
Old Dec 23, 2020 | 09:40 PM
  #48
ShaneN.'s Avatar
2018 e63s edition 1
I mean, if you watched the video in the original post and/or read any of the replies prior to replying you'd likely know, but I'll help you out. The caps in the Amazon listing are the two of the pieces supplied in the weistec kit. They're the only two things you technically need to do this mod, so you're blocking the now empty holes in the air box when removing the two tubes. The actual aluminum pieces in the kit you bolt on don't do anything and are simply added in to be able to call it a kit and list it for 150usd. As per the suggestion in the video, Im tempted to just order the caps, remove the tubes and remove the plastic pieces bolted onto the bottom section(or just leave them on). However in another thread Zac motorsport commented on it probably being best to take them off so its not directing hot air at the hood (since they're kind of an elbow piece where the tube attaches)
Old Dec 24, 2020 | 06:09 AM
  #49
nw66's Avatar
E63S 4MATIC 213
What car do you have a W213 E63S 4Matic+?? I have a set of weistec on mine they work fine without rubber Amazon plugs!
Old Dec 27, 2020 | 12:23 AM
  #50
ShaneN.'s Avatar
2018 e63s edition 1
Considering you're in the c63s section of the forum, no, I don't have an e63s. This could by why you're confused about what they're for, it's a difreent setup.
