BOOSTANE Octane Boost_Tried and Tested
Former Vendor of MBWorld
We tried the Boostane Octane Booster and have had some really incredible results. Since we are in California and suffer from horrible 91 Octane fuel, we were searching for a decent solution. Unlike most Octane boosters, the Boostane app (available on IOS and Android) helps you determine how much octane booster you need to add to your gas. Download the app for free on your smartphone to try it out.
I would recommend buying a case of octane booster and leaving it in the box in your trunk and add it to your fuel every time you fill up.
We have tested this on the dyno and it makes great power with California fuel.
We sell this by the can and the case. If you are coming to use our dyno I suggest that we throw a can in after all your power runs to see what kind of horsepower and torque you are leaving on the table by not using this stuff. Everyone that has tried it on the dyno has bought a case when they left.
If you have any questions please feel free to ask me.
If you want to purchase some and try it for yourself please feel free to stop by our shop in SoCal.
How does this compare to mixing in a few gallons of E85 to boost octane?
$30/quart (per fill) seems awfully expensive when you can get a gallon of E85 for a few bucks.
You do not need to use a whole quart per fill. If you download the Boostane app you will see it offers a digital guide to give you a recommended amount to add in order to achieve the octane rating that you desire.
I understand you can use less with half a tank, but the ratio doesn't change. I also don't see how this has any benefits to using an E85 mix which has a much higher octane rating at a fraction of the cost.
Assuming you want at least 100 octane out of an 18 gallon tank, it requires .9 quarts according to the calculator...
This could be dangerous for many vehicles as fuel lines may not be able to tolerate high levels of ethanol. Most vehicles are warranted for a maximu of 10% ethanol, and that's coming from the pumps in many jurisdictions.
I would strongly recommend against this in anything other than a vehicle specifically designed to handle Hugh ethanol concentrations.
Having said that, I also think octane boosters are a waste of money for 90% of us.
NOT SAFE!
There is a big push in the industry now for an E15 (15% ethanol) fuel standard. Less than 20% of vehicles on the road are built to handle this (though about 75% of MY16 cars are) - and virtually no car produced before 2012 can handle. Nissan, Hyundai, Kia, Mazda, Volvo NS Subaru have explicitly stated that their cars are not compatible with E15.
The benefits (which are virtually non-existent for a stock car) certainly do not outweigh the costs, including risk to the car.
I'm in England and awaiting delivery of my first MB (C43 Coupe).
We get 95 octane as standard. All filling stations sell 97or 98 as an upgrade and a couple even sell 99.
My question is what should I put in my AMG? Obviously there is an increased cost (and our fuel cost more than US/Canada anyway).
I'm guessing the 97/98.
Seems nuts that there are C63s' + all of the super cars cruising around LA on sub standard juice!
NOT SAFE!
And, before I start getting flamed, when I say lower grade than recommended, I don't mean just what's on the fuel door, there is a range that the manufacturer allows in tuning the vehicle because fuel production is never a perfect science, as well as water vapor and other impurities can effect the octane rating. Therefore, the range of tuning.
For example: Most high performance cars in the USA have a minimum of 91 but are rated for 93. All specs, i.e., horsepower, torque, etc., are done using 93 and you can ABSOLUTELY feel the difference, which is why I contributed and was interested in this thread.
On my S4, I immediately noticed a difference over the CRAPTASTIC California 91 when I added 2 gallons of e85 to the mix, boosting the Octane to just over 93. There is ZERO point to going OVER the tuned range of your vehicle, it's a waste of money. BTW - It was an ABSOLUTELY NOTICEABLE increase over the entire range.... It was like I bought a tune.... and then, I did just that because it was addicting.
You will notice, a bonus when you increase your Octane to the max range: Increase in mileage, as well as the horsepower/torque. The EPA is just stupid in states where they force the 91 thinking they are saving the environment, it's actually the opposite. They are causing more spent fuel and oil, because there is a 2-5% mileage penalty on those vehicles that require the higher octane fuels, and the ultimate benefactors are the Oil Companies who actually make more money by diluting the additional Octane over the other fuels.... but I digress.
So back to the topic at hand: Does this Octane Booster leave the typical pink residue detectable by the dealer, if you are saying e85 isn't safe at a 22% total content level in the tank of these cars, to increase the Octane to 93?
Thanks. That's interesting, I wasn't having a pop at the US...
Our pumps all clearly state RON (not MON or AKI) at the point of sale so but I now appreciate calculation methods differ? I will go away and have a read up.
Cheers
It's all good... Of course, I didn't write the response in question, but I certainly didn't read your post negatively at all.
Are you saying then that an octane booster is safer? They typically leave behind a pink residue in the fuel tank and on the injectors, over time, which can be detected by the dealer and therefore void most warranties, whereas ethanol, in small quantities cannot, just to bring crappy 91 to 93....
Risking the integrity of your fuel system by using high-ethanol fuel which won't improve your performance, but will reduce your fuel economy doesn't make sense to me.
All octane boosters are total gimmicks. This one is no different.
The only real octane booster is Toluene, and you need GALLONS of it to make a substantial difference. It's 114 octane and can be bought at any local Sherman Williams for $15 per Gallon.
Everything else is a complete waste of money and is snake oil by comparison
Mr. J (08-20-2016)
