C63/C63S AMG
Turning up the wick on the C63 s
Old Sep 10, 2016 | 05:46 PM
LoneStarFlyer's Avatar
2013 ML550; 2018 C43 AMG; 2016 Porsche GT4
I'm strongly considering ordering a 2017 C63 s coupe, and despite my research, I have not been able to determine what MB does to up the engine hp and torque on the 63 s model versus the base C63 model. Is it as simple as a boost adjustment, or is there more to the equation?
Old Sep 10, 2016 | 06:01 PM
bgm130's Avatar
2016 C63S
It's just a more aggressive tune. Everything else is the same
Old Sep 10, 2016 | 06:33 PM
Not sure what is "tuned" to make that type of power difference. Timing, sure, but that won't account for the difference. I assume cam and internals are the same. Boost is the only other variable I can think of that might account for the power spike. What else might be "tuned"?
Old Sep 10, 2016 | 06:34 PM
Biggreenogg's Avatar
2017 C43 sedan
ECU?
Old Sep 10, 2016 | 06:54 PM
I'm sure the ECU is involved, but the "tune" has to be adjusting certain engine parameters to effect the power increase. Not a huge deal as the S model carries other worthwhile improvements, but I'm just curious how MB bumps the power. I'm thinking it's primarily a boost bump, courtesy of the ECU.
Old Sep 10, 2016 | 07:09 PM
2017 C43 sedan
http://www.renntechmercedes.com
Old Sep 10, 2016 | 07:39 PM
EkS's Avatar
EkS
C63
More HP is achieved by software, so anyone of the tuners like Weistec can up your HP. But you still get more than just HP by getting the C63S Vs.C63.
Old Sep 10, 2016 | 08:32 PM
ItalianJoe1's Avatar
2003 CL 600
The factory maps have higher desired torque values, so the ECU will run more boost/timing to get to the higher amount of power compared to a car with less rated power.
