C63/C63S AMG
Mode Carbon Mirror Cap Installation
Old Nov 17, 2016 | 08:17 AM
RDO247's Avatar
C63S
I thought I would post a step by step guide to installing a set of Mode Carbon Mirror Caps.
Standard mirror
Standard mirror housing
Use controls to turn mirrors all the way in towards the car and facing down
Squeeze fingers behind the mirror getting a good firm grip
Carefully pull the mirror out until it unclips
Firmly grip the mirror pulling rewards to fully unclip from the electric motor
Unclipped - position mirror glass so it does not scratch the paint
Be careful that your mirrors don't self close at this point and break your mirror glass or scratch your paint
Locate securing tabs and use flat head screw driver to unclip - Tab One
Tab two
Tab three
Push the mirror housing rewards unclipping from the main mirror
Remove housing
Locate two security screws securing the Led light
Remove the screws
Tools used
Unclip the tab on the end of the led light
Push the led light inwards and remove fully placing into new carbon housing. Clip and secure with the two screws.
Slide carbon fibre mirror housing onto the mirrors ensuring the three clips are secure
Push mirror glass back into position and reposition
Old Nov 17, 2016 | 11:16 AM
bgm130's Avatar
2016 C63S
i was actually able to pop mine off without touching the glass. It was a bit scary but it worked.
those look great by the way.
Old Nov 17, 2016 | 12:26 PM
Uga Uga's Avatar
2021 C63S coupe
Thanks for sharing. No doubt will come in handy in the future.
Old Nov 17, 2016 | 01:12 PM
NSAMG's Avatar
AMG GTR
Excellent. Pictures are worth a thousand word.. thank you.
Old Nov 17, 2016 | 02:00 PM
OrientBlue3's Avatar
ED1 e63S
Thank you for this!
Old Nov 18, 2016 | 05:25 PM
darwin329's Avatar
w205 c400 c63s
Thanks for the demo! same installation for the driver side w/ dimmer
Old Nov 18, 2016 | 07:47 PM
RDO247's Avatar
C63S
Yes, this was the drivers side as this is on a right hand drive car.
Old Nov 20, 2016 | 01:34 AM
SBH-'s Avatar
C63S 2016
Standard mirror
Tab two
Tab three
Remove housing
Remove the screws
Tools used
thanks for sharing. and its looking good buddy
