C63/C63S AMG
Heads-Up Display.
Old Nov 22, 2016 | 01:47 PM
the_big_1's Avatar
C63
Heads-Up Display.
Hi All,
Have any of you got the heads-up display?
I can not find how to change to the AMG via with the shift lights etc.
All I can get is the standard with sat-nav and another with rpm bar and gear number etc. When I press the heads-up button, it cycles between the two and off.
How do I get the shift points etc?
Old Nov 22, 2016 | 07:52 PM
RDOCA's Avatar
2016 C63S Sedan
Originally Posted by the_big_1
Hi All,
It doesn't say what C63 you have so this is only 2015/16 C63S with the flat HUD bar as I think the 2017 changed.
they will come up automatically when you go to manual.
Old Nov 22, 2016 | 08:08 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
This is correct.
The new 2017 doesn't have it... my 2015 did!
Old Nov 22, 2016 | 08:14 PM
Trim105's Avatar
C63S Coupe/Range Rover Vogue SE
Originally Posted by Sanch
This is correct.
Sanch, the shift indicator comes up for me once I'm in manual mode with the AMG display on (both temporary and button activated manual mode)
Old Nov 22, 2016 | 08:20 PM
Sanch's Avatar
Hummm... I will have to try it again when I get in the car!
Old Nov 23, 2016 | 02:11 AM
the_big_1's Avatar
C63
Hi,
mine is a 2015, June 2015 registration date.
So your saying have AMG screen on dash (Shows boost, Oil temp, Transmission temp?). Have heads-up with flat bar then select manual mode?
Old Nov 23, 2016 | 05:07 AM
Trim105's Avatar
Hi,
No need for the AMG menu in the dash screen, I was referring to heads up mode with the rpm bar but yeah, change to manual and the shift indicator should appear
Old Nov 23, 2016 | 07:42 AM
the_big_1's Avatar
C63
Will try it again tonight. I am sure I tried it and no sign of shift lights unless they appear as the revs build?
Old Nov 23, 2016 | 09:35 AM
Trim105's Avatar
You're right on the ball. While the shift indicator will definitely appear, the shift lights only start to appear as you get closer to the redline.
Old Nov 23, 2016 | 01:04 PM
RDOCA's Avatar
2016 C63S Sedan
+1
Also as you said the 2 screens with the RPM/gear/MPH are AMG specific screens and you have to use them and manual to get the bars/lights.
