C63/C63S AMG
Disable ECO Mode on C63S
Old Dec 24, 2018 | 10:46 AM
Star4life's Avatar
2017 C43 AMG
Originally Posted by Bsanta01
Originally Posted by ignomini
Not got my Coupe yet, but if setting the drive mode every time you start the car sounds dumb, try this:
http://www.midcityengineering.com/pr...***-2015-2016/
Spoke with them and they say the product works on 2017 models as well. I will be going this route.
Does it work with 2018 models?
Likewise, does this work on the 2019 C63s? how is it installed?
does this work on amg cars? I hardcode this feature and found that it is easy to code on c300s but all the amgs do not have a software option by default in the engine ecu thus whatever they are doing would void warranty. I would double check with them that it works on the amg variants.
Old Dec 26, 2018 | 09:07 AM
C6Jeff's Avatar
2018 C63SA Cabriolet
I select S+ every time I start the car so I don't have this problem. It takes a second to make the selection and is part of the startup routine so it becomes almost automatic.
Old Dec 26, 2018 | 09:12 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
Yes, I don't get all the angst. It's no different than putting the stick in reverse or drive....takes a split second. Start up the car, select your drive mode, turn off start/stop...it's as simple as that.
