C63/C63S AMG
Best Spacers for C63s Coupe 17
Old Jan 9, 2017 | 11:27 AM
Vic55's Avatar
Administrator
Originally Posted by JPMBenz
Has anyone tried a 305 on the rear wheel?
I dont know of anyone on the coupe but I think its possible albeit not optimal on the 10.5 inch wheel. If lowered then it would be ok depending on the drop but without spacers. My car needs the slightly stretched OEM tire with the 18mm spacer.
Old Jan 9, 2017 | 05:59 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
I'm now running 295s with a 10mm spacer... no rubbing and looks great!
New wheels coming soon though.
Old Jan 9, 2017 | 09:04 PM
JPMBenz's Avatar
17 C63 S Coupe
I know what you're saying. The 285's look out of place on that wheel; the 295 is the way to go.
Pics?
Old Jan 9, 2017 | 09:12 PM
auditoamg's Avatar
C63s
Where did you get 10mm spacers that fit??! Are they give centric??? Ecs had nada. I can't find anything....
Old Jan 9, 2017 | 10:50 PM
Sanch's Avatar
Pics?
Here you go JP!
305s would fit but like Vic said they need a stretch and will look bulky on a 10.5 wheel.
20mm front - 10mm rear
Old Jan 9, 2017 | 10:54 PM
Sanch's Avatar
I had my old 12.5mm on there... it rubbing with the new tires.
The shop was able to machine them down by 2.5mm - No rubbing and looks sweet.
Audio - You've been on the hunt for these spacers forever lol...
I have new forged wheels coming in the next few weeks, if you want I can sell you my ones as I won't need them anymore. You can DM me if interested.
Old Jan 9, 2017 | 10:58 PM
  #32
Sanch's Avatar
FYI my car with the 285s (Spacers and drop) - The stretch is ridiculous IMO looks incomplete, go 295s for anyone wanting to change in the future.
Old Jan 10, 2017 | 02:06 PM
  #33
masar's Avatar
Shelby GT350R, Ford Raptor
Will 20 mm on rear fit with stock tires? I want 20 mm on both sides. Will be lowered by KW HAS.
Old Jan 10, 2017 | 05:48 PM
  #34
Sanch's Avatar
It will fit, however it will stick out quite a bit.
Vic is running 18mm, that is the widest I would go with.
20/18mm front and 15/18mm rear works well when lowered with KW has
Old Jan 10, 2017 | 08:19 PM
  #35
Vic55's Avatar
Administrator
Concur here- 20mm in the rear on a lowered coupe will push the wheel lip out too far and while the tire is slightly stretched it will look just a bit too outside.
Sanch how far did you drop your car? Im basically as low as I can go in the rear with about 1 1/4 inches left in the front = weird KW HAS
Old Jan 10, 2017 | 09:37 PM
  #36
Sanch's Avatar
Vic, I'm about 18mm lower all around. This may change when I get my wheels.
I use it as my daily and any lower I would scrape the front getting in and out of driveways. I'd love your height!
Old Jan 11, 2017 | 06:11 AM
  #37
masar's Avatar
Thanks, i am buying H&R spacers available here in Europe and they do not make 18 mm. So i take 20 mm and hopefully its ok. In worst case i can machine the 2 mm off.
Old Jan 11, 2017 | 06:47 AM
  #38
michael640D's Avatar
2018 E63S,2016 C63 S Edition 1 Coupe(gone), 2011 640D M Sports Coupe, 2015 435i M Sports Coupe
Sanch I see you have Michelin's fitted to you C63 S are these standard tyres in Sydney as in UK my C63 S Edition 1 came with Continentals as standard. Do you find the Michelin grip well on damp/wet roads.
Old Jan 11, 2017 | 02:01 PM
  #39
Vic55's Avatar
Administrator
Ill answer from my perspective--- my car came equipped with the PSS tires and they are arguably the best overall performance tire out there when you have to blend dry and wet. A few tires have made some strides and are closing in but the PSS, for me, has been the best of the lot. There are tires that are better only in the wet and only in the dry but the PSS is the "all rounder" for cars at our level and beyond. I do have P Zero's on my M5 and Turbo S but thats because they were the OEM option in the states.
Old Jan 11, 2017 | 06:46 PM
  #40
Sanch's Avatar
+1 VIC has nailed it - PSS are top notch in wet and dry conditions.
If you want to change I would recommend PSS. However, there is a new version (supposedly) much better. They will be rolled out on the new AMGs models including the W213 E63s. This will be worth the wait. I can't wait to try them.
Michelin pilot sport 4s
http://blog.caranddriver.com/micheli...lot-sport-4-s/
I had Dunlops on my 2015 sedan... they were terrible. lol
Old Jan 11, 2017 | 07:46 PM
  #41
AlexZTuned's Avatar
2017 Porsche 911 C4
I'll be switching to these for sure when I'm due for a replacement and upsize. I also first noticed them on the E63S press photos. Can't wait to try them out!
Old Jan 12, 2017 | 06:22 AM
  #42
OK guys what make are PSS ?
Old Jan 12, 2017 | 06:25 AM
  #43
OK sorry I see now Michelin PSS thanks
Old Jan 12, 2017 | 09:20 AM
  #44
Are the PSS better than the PSC2 in respect to both dry and wet driving.
Old Jan 12, 2017 | 11:00 AM
  #45
Vic55's Avatar
Administrator
Yes as a blend for sure as the SC2's are down right scary in the wet and I would not recommend driving a car equipped with them in that scenario. I had a 2015 GT3 with those tires; tremendous dry grip (better than PSS) but in the wet the car stayed garaged.
Old Jan 12, 2017 | 07:14 PM
  #46
NSAMG's Avatar
AMG GTR
Here you go JP!
This is what I am aiming for, great picture thanks.
Old Jan 12, 2017 | 08:47 PM
  #47
JPMBenz's Avatar
17 C63 S Coupe
Anyone have a pic of 295's at the rear with spacers lowered? Thank you.
Old Jan 12, 2017 | 10:01 PM
  #48
C63SEd1's Avatar
2017 C63S Convertible
I stopped by a local Performance shop today to get some ideas today, and the owner recommended against getting spacers.
Has anyone experienced any side effects such as rattles, shimmy or rubbing?
Thank you
Old Jan 12, 2017 | 10:19 PM
  #49
Sanch's Avatar
Jp my coupe does... See above. 295s 10mm spacer 18mm drop
Old Jan 13, 2017 | 10:22 AM
  #50
Vic55's Avatar
Administrator
Thank you
You will hear a lot of noise about spacers based on bad and good experiences. I have found that the bad ones are due to misfitment and lack of a hubcentric connection. If you get a hubcentric spacer which binds the spacer to the factor snout you will be just fine. I have been using spacers for years on factory OEM wheels with zero issues as long as they are hubcentric in nature.
Hell, Porsche has an addendum on their 991's for a spacer add (I think 7mm) that comes on the car from the factory.
So currently on 3 of my rides (just dumped the M4) I have spacers with OEM wheels: M5, C63S, and my departed M4. I have had zero issues with vibrations, balancing, anomalies, rubbing (which is more of an issue of how low you go) or steering wheel concerns. I like to think I drive my cars hard, reaching triple digit speeds a lot and push the cars into turns and big bends. I don't baby my rides. What was the owner's reasoning? Did he want to sell you a set of wheels instead (and tires)?
