Who has the Rebellion Tune?
It's not an easy install per se.. but IS significantly easier than the ECU tune route, and anyone with some ability to follow instructions should be able to install. Small hands help.
I do have an issue, in that if I've been driving around on a hot day, esp in slower traffic.. then park for a short while, allowing just enough time for the turbo heat to soak through the engine bay (and into the piggy) the car will not start correctly, have very rough idle, and just die. As soon as I unplug the piggyback (and put in the jumper), it starts right up fine.
I've sent it back once for them to look at it, and they sent it back with a new flash.. which didn't help. Car runs great with the tune otherwise. However, I'm starting to look at a 'stage 2/3' ECU+turbo upgrade route.
With th the downpipes you can ge the ECU flashed with a stage 2 file and get more HP so that is the the obvious route to go. The module isn't as easy to remove as on other cars so you are not going to want to take it on and off before trips to the dealer or anything like that
