Exhaust Rattle C63S coupe.
#276
700HP Facelift converted PFL C63 S Coupe
Totally forgot how rowdy this car sounded especially the upshift gear change burp *** blew me away.
Random gurgles on the overrun and when coming to a stop are back now too. Happy days
#277
2021 Mercedes C63s AMG Coupe
Thanks for the pic man I needed this today. Ended up getting mine welded and locked & plugged in the AWE simulator. No more rattle.
#278
Thank God for your pic though.
#279
Another option for those who are interested in keeping the factory H pipe setup for optimum sound, you can now buy a high quality H pipe from these guys $450 which fits with your current factory actuator/motor.
Just cut the old one out, weld this one in and it'll fit your with your existing actuator motor.
Specs say it'll fit 3" piping.
Can anyone confirm the size of our factory H pipe? Is it 3"?
#282
Gotcha. Makes sense. So then what would be the advantage of the Holley product over the spot weld and AWE simulator? Is there something better about the Holley product that improves the sound and/or quality of the H-pipe valve over stock?
#283
The Holley valve flap also use existing Kuster valve motors (ours). So it's just a weld in and you're set.
From my experience during this saga, the way our H-pipe valve opens and closes depending on RPM works really well for sound. Especially if you have secondary cats removed, it's always nice to have a functioning H-pipe.
As you know, keeping the H-pipe open all the time will rob you of the deep sound, but having it shut the whole time also gives you a bit of in-cabin vibration on light throttle under 2000-2500rpm when the exhaust is "ON". This is what I experience with my coupe and the windows are up and having the secondary cats deleted.
It sounds menacing with the H-pipe closed permanently when you're driving hard, but sometimes when you just want that nice, throaty sound without the vibration drama, you can see why the H-pipe exists as it will Open to reduce drone as you take off, but Close as you're accelerating. Hence why the rattle happens above 2500rpm because this is when the H-pipe valve begins to close and the rattle is from the spindle (the round part that the spring sits on top of) not being completely shut, due to weak spring tension.
And that's why when you stretch the spring, it will be able to hold down the spindle harder whilst the H-pipe starts to close and exhaust gasses are hitting the closed flap.
Having weak spring tension allows just a small amount of play in the round spindle (where the spring sits on). This spindle begins to "tap" back and forth as exhaust gas passes the flap in it's closed position due to the weak spring tension.
You can emulate the rattle by taking off your valve motor and twisting the spindle rapidly. The "tap tap" sound from this spindle is the actual rattle you hear. Not the flap that's inside the H-pipe.
#284
Thank you for the clarification. So does this mean that I should still plan to adjust the valve motor spring tension even if I get the Holley H-valve?, in order to eliminate rattle? Or does the presence of the better (Holley) valve eliminate the need to adjust spring tension?
#285
Earlier AWE exhausts had some H-pipe issues in the past but this has been fixed for at least 3 years now.
I've also been researching other forums and car makes such as Mopar, Audi, Ford and Volvo who also have members who've used or added these Holley valves to their aftermarket exhaust setups and they are of very build good quality. I guess that's why they are a bit pricey, too ($430 USD).
In the meantime, if you want to keep your H-pipe functioning without the rattle, the guaranteed way to fix the problem on our H-pipe is by increasing spring tension.
I've even used a stretched out/upgraded spring (below) and it worked but it was just way too tight of a fit and I didn't like how it pushed too hard against the valve motor's plastic spring seat.
Stretching our spring to increase tension a bit is still the best way if you want to keep the factory H-pipe working and rattle free.
#286
And the link for Holley, provided earlier in this message thread, which directly goes to the
It will also fit for 2021 C63S AMG with Performance Exhaust?
HOOKER BLACKHEART ATTITUDE ADJUSTER EVC
Replacement Valve...It will also fit for 2021 C63S AMG with Performance Exhaust?
#287
Also, on this thread, I have separately read multiple posts that say the opposite in regards to when the exhaust noise is louder. Some state that exhaust volume increases when the H pipe valve is either fully open, or absent. And have read where people weld the valve shut and that is what makes it louder. Can anybody provide clarity with this?
#288
Just to confirm one thing here...
Is the aim of stretching the spring:
A) To apply more anti-clockwise force to the spindle to keep it closed, or
B) To apply more axial load (pushing towards the spindle) to stop some other chattering?
I see a mix of diagrams and photos and just want to clarify before I go ahead and mess with the spring this week.
Cheers
Cheers
#289
wrong.
The car loses its growl if you keep the valve open.
i know this because initially I thought keeping the valve open would equal max sound but like you said the car lost its growl.
welded a metal disc in between after and voila all the growl was back without the annoying rattle.
This H valve is just too faulty. Even the one I got with the AWE Track exhaust started rattling. Could have ordered a new pipe under warranty but wanted a more permanent solution so fixed it the same way
#290
Sorry to bring up an old topic, but was looking at welding my H valve shut to enhance the sound (thanks @untamedd for experimenting) and then got into thinking in order to prevent limp mode, or modifying the valve or using simulators to trick the car. Would it have the same effect welding a disk on either side of the h valve? That way the h valve is still free to open/close as per programmed logic but no exhaust flow going through? Thoughts?
#291
2021 c63s
Hey guys I read through all the comments and what people did to remove that tattle coming from the middle actuator flap. I just bought a 2021 c63s and imideattly I had the rattle issue. The dealer even replaced all 3 actuators including the ones on both mufflers but the rattle was still there. I took it the car to a mechanic exhast shop I trust and have been going to for over a decade. They ended up removing the spring in the middle of the ahaust where that spring is and welding the flap closed. The rattle is completely gone but now the car is not as loud with the valve shut closed. I have two questions. If someone could shed some light.
1.Is removing the spring and welding the middle valve close create any issue? Or can? (Might be a stupid question I apologize)
2.How do I make the car louder? Do an x or h pipe and bypass the actuator by puting in a bypass plug? I am trying to avoid doing cattless downpipes.
#292
When it's welded shut the car is DEFINITELY louder and more "boomy". I hated both as the boomy noise would sort of drone at times so I completely replaced the H-pipe section with a second hand one and reinstalled the valve and used the uprated spring. Every now and then I will lubricate with a bit of copper grease and I haven't had a rattle in 12 months nearly. Thank fuuck
#293
Drove a bit more and ill share my final thoughts.. startups are more aggressive as the car seems to pop more. I do hear pops and crackles randomly even in C mode. The H valve would change the tone of the exhaust as you accelerated but as one would expect without the valve, the sound is constant as you now have a fully open H pipe. At least my car doesnt sound broken with all that annoying rattling!. Hope this solves some of your rattling issues!
#294
Hey guys/gals,
I’ve been having the same issue with my 2017 C63s coupe with AWE track exhaust - yes even the h-pipe from AWE has issues….
I had my h-pipe replaced by AWE under their warranty back in April 2019 due to the valve making noise at idle…. Thought I would be done with this issue…
Fast forward to Spring 2023 - now the H-pipe is making a rattling noise = its coming from the h-pipe… Had it checked out and the valve is rattling - so bad at idle - makes me not want to drive the car and I love driving my car…. Reached out to AWE on Friday and waiting back for their response… I know it’s out of their warranty now but this is ridiculous…. Same issue 4 years later and now I see its not only me…
So it’s not just stock AMG performance exhaust - h-pipe having issues, but even aftermarket exhausts like AWE that are having H-pipe valve issues….
I might just do what everyone else is and have my h-pipe valve welded closed…. Going to see what AWE can do…..
I would post a video with the car idling and another video under my car when we were assessing the h-pipe valve but I’m not sure how to post videos ?????
I’ll keep you guys posted….
#295
I’ve been reading through these pages and I’m having a similar problem, but mine seems to be more of an exhaust leak (ticking at 1500-3000rpm under load. The odd thing is, it only happens when the exhaust button is on (H-pipe flap closed). There is no noise when the exhaust button is off (H-pipe open). Does anyone have any suggestions? Perhaps I have an exhaust leak at the valve?
Thanks in advance
Thanks in advance
#296
Thanks in advance
Thanks in advance
Or you can get an exhaust place to weld the leaks for you. Check the H-Pipe section in particular
#297
2019 Mercedes C63s Coupe
I seem to be having this strange rattle now as well. It happens under mild load from 2.5 RPM to 3.5/4 RPM. 2019 C63s with secondary cat delete. What seems to be the final fix for this? Thanks for the help.
#298
Easiest thing to do is just lubricate it with copper grease from the tub every 6 months. I use a small syringe and pump it through the holes it 100% works I've been rattle free for over 12 months now
#300
I guarantee you it will work. The copper grease becomes a cushion and stops the flap from "clanging" on the cradle. That's what causes the rattle in the first place.
Mercedes lubricate it but their lube always turns hard after a few 100 miles and the rattle comes back. The copper grease won't go hard.
Please let us know how it goes. You only need to use 3x 5ml syringes worth and that rattle will be solved.
I use this syringe and poke it through the cradle holes to pump the grease in
