C63/C63S AMG
Exhaust Rattle C63S coupe.
Old 10-10-2023, 04:29 AM
  #301
mokawop's Avatar
c450
Hi, are the cradle holes the 4 holes on top of the valve?
Old 10-10-2023, 04:54 AM
  #302
Jimmy_c63s's Avatar
700HP Facelift converted PFL C63 S Coupe
Yes they are. This is where Mercedes insert the nozzle of their grease to lube the flap without having to remove the black flap motor.
If you're under the car this is what the H-pipe will look like:
Old 10-10-2023, 05:47 AM
  #303
mokawop's Avatar
c450
Thank you!
Old 10-10-2023, 06:36 AM
  #304
Jimmy_c63s's Avatar
Thank you!
Can you let us know how it goes with the copper grease? Thanks
Old 10-10-2023, 07:14 AM
  #305
mokawop's Avatar
c450
Yea, Ill try it tomorrow
Old 10-10-2023, 07:19 AM
  #306
mokawop's Avatar
c450
Hey, do you know exactly which grease you used?
Old 10-10-2023, 07:25 AM
  #307
Jimmy_c63s's Avatar
Penrite Copper Eze it's a cheap product in Australia they are all the same. Copper grease in a tub don't use the spray-on one as it's not thick enough
Old 10-10-2023, 07:26 AM
  #308
mokawop's Avatar
c450
Gotcha, Ill let you know how it goes.
Old 10-10-2023, 07:28 AM
  #309
Jimmy_c63s's Avatar
Thanks please do as I'm 100% certain it'll cure it and just hoping others can get theirs fixed too after seeing your feedback tomorrow 👍
Old 10-10-2023, 11:09 PM
  #310
mokawop's Avatar
c450
Greased and test drove. Little excess came back out the holes so I wiped that down as well. My car originally didn’t rattle that much, but you could notice it during light load and idle. Car sounds much better/cleaner without the rattle. Family also thinks it doesn’t sound like a tin can now
Old 10-11-2023, 12:17 AM
  #311
Jimmy_c63s's Avatar
How good is it without the rattle aye?
You're all set now man didn't I tell you it would work with copper grease! Did you do the H-pipe only or all 3 flaps?
Here is a clip of mine just after greasing the H-pipe and mild acceleration in 3rd. Zero rattles
https://www.instagram.com/reel/Csq5uZNJchY/?igshid=MTc4MmM1YmI2Nghttps://www.instagram.com/reel/Csq5uZNJchY/
Old 10-11-2023, 01:08 AM
  #312
mokawop's Avatar
c450
Haha definitely enjoying the clean exhaust note. I'm glad people won't think I'm driving a tow truck anymore. I did all three flaps as my mufflers were actually a little worse than the H pipe. Hopefully it stays this way for a while haha
Jimmy_c63s (01-07-2024)
Old 10-11-2023, 01:23 AM
  #313
Jimmy_c63s's Avatar
Glad it worked man.
It will stay that way for at least 3 to 6 months then as the grease gets dried you'll need to grease the H-pipe again one more time and that's it. It will never rattle again.
Mercedes had the right idea with lubricating the flaps but their grease is sh*t because it can't handle the heat and hardens up after a few weeks. Copper grease won't harden like the Mercedes grease does, it just becomes a tiny bit dry and thick but won't harden up.
mokawop (10-11-2023)
Old 10-11-2023, 01:37 AM
  #314
mokawop's Avatar
c450
Gotcha, thats not too bad. Thanks!
Old 10-13-2023, 10:16 AM
  #315
George_1992's Avatar
C63 S Coupe
The copper grease fixed up my hpipe middle flap rattle too it's been 8 months now. Jimmy's trick works 👍👍👍
Old 01-07-2024, 03:23 PM
  #316
untamedd's Avatar
2017 C63S Coupe
Originally Posted by Jimmy_c63s
Glad it worked man.
hey Jimmy im guessing the same process will apply to the muffer valves too? Insert the lubricant in the holes in the valve assembly?
Old 01-07-2024, 05:27 PM
  #317
Jimmy_c63s's Avatar
That's right same process brother make sure it's the thick copper grease from the tub too not the thin spray type and you're good to go.
Old 01-07-2024, 06:37 PM
  #318
untamedd's Avatar
2017 C63S Coupe
Will either of these work or should i be looking at something else?
https://www.canadiantire.ca/en/pdp/p...per+grease#srp
https://www.weicon.ca/anti-seize-cop...paste/10027280
Old 01-07-2024, 06:45 PM
  #319
Jimmy_c63s's Avatar
Get the Permatex one. Cheaper and temperature range from -34C to 980C.
untamedd (01-07-2024)
Old 01-09-2024, 10:11 PM
  #320
DoubleD748's Avatar
2022 GLE 63s AMG
How long after applying the grease did it take for the sound to go away? I have a 2022 GLE63s with the same exact rattle problem being described here. I used about 4 of the 5ml syringes and the sound is still there. Would you put more or try something else?
Old 01-09-2024, 10:17 PM
  #321
n0mad17's Avatar
BMW M3
Use a torch on the spring and stretch it a little. This is the fix
Old 01-10-2024, 02:14 AM
  #322
DoubleD748's Avatar
2022 GLE 63s AMG
is this the same method as munis describes in post 267 on this thread? I don’t know how to make a link to it
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
