C63/C63S AMG
No spacers fit
Old May 22, 2020 | 05:03 AM
  #51
notbadgoodsize's Avatar
C63S Edition 1
Originally Posted by TeraPatrick
I wanted to give you my take on the whole spacer subject. I ran 17.5 and 15 in the back when I had stock tires. It fit almost perfect until I upgraded my tires to P4S's. My new tires were 265/35/19 and 305/30/20 and my car started to rub (rear tires) going up bumps and driveways. This is on stock suspension might I add. Now I'm stuck without spacers, but I might try 12mm in the back and 17.5 in the front to see if it works out. This car is a coupe.
Originally Posted by See63esS
I am on the same tire and stock height and still rubbed with 12's. I took them off and went with 5's.
Lifted it up about 10mm and it was still scrubbing, they suggested we machine 2mm off the spacers and it will fix the scrubbing. I may change the front to 18mm as well
Old May 22, 2020 | 11:18 AM
  #52
ModalWorks's Avatar
SPONSOR
W205 C63
Machining 2mm off may not work.. the internal hub bore might need to milled deeper to clear the wheel hub. If they aren’t designed with enough material you will compromise the structure. We have 12.5mm spacers available if you’re interested.
