C63/C63S AMG
Black Mercedes Hood Badge P/N
Old 06-14-2017 | 09:51 PM
  #176
rswaltz1614's Avatar
2012 C300
Already have the star in the grill....
Old 06-15-2017 | 07:45 AM
  #177
NOPDK's Avatar
2019 AMG G63, Porsche GT4, 1973 Porsche 911 hotrod
My black hood badge was only clipping down on one side. The fix for this is to grab tab of plastic on back side of badge from inside the hood on side that clip is not fully engaging. Pull down on badge while pushing the spring lock tab over. With the pull on the badge the tab will slide over and lock badge down on both sides. This worked for me. Hopefully, others find this solves their mounting issue.
rswaltz1614 (06-24-2017)
Old 06-15-2017 | 07:46 AM
  #178
NOPDK's Avatar
Grab the back of the hood badge with needle nose pliers
Old 06-15-2017 | 08:09 AM
  #179
tresean1's Avatar
Veteran: Marine Corp
W212 E-class, W211 E-class, F10 5-Series
+1. This is what I tried to convey above.
Old 06-24-2017 | 12:19 PM
  #180
2012 C300
Ok so with great embarrassment/ remorse - I'm swallowing my pride and realized I made a mistake.....no let me re-phrase - I ****ED UP....
Apparently - the item was NOT purchased from mbpartscenter.com but instead a different vendor. My wife told me she bought from mbpartscebter.com on accident when it was actually a very similar site name - my apologies to mbpartscenter.com
Old 06-24-2017 | 02:00 PM
  #181
tresean1's Avatar
^interesting. So was it indeed user error? Was the part OEM?
Are you still still with the accusation that the part was defective?
Old 06-24-2017 | 02:10 PM
  #182
Lionel_Hutz's Avatar
C43
You really ought to delete your posts accusing mbpartscenter of doing something wrong, then.
I'll also bet you the cost of a replacement badge that your dealer didn't clip it in properly. There's darn near nothing that can be "defective" about the badge that wouldn't caught by a competent inspection. It's a piece of plastic and two springs.
Old 06-24-2017 | 05:41 PM
  #183
tresean1's Avatar
+1
Old 07-15-2017 | 02:14 AM
  #184
tomofva's Avatar
Will this fit a W140?
Anyone know if Part Number: 000-817-17-01 will replace the badge/ornament on a W140? The hole looks the same
Old 07-15-2017 | 05:08 AM
  #185
tresean1's Avatar
yes, it will
Old 07-18-2017 | 09:25 PM
  #186
BuckeyeBenz's Avatar
2018 GMC Sierra Denali
Does anyone know which part # will fit a W212? I called my part dept today and after giving them the parts # I found previously on this thread they said the new ones will not fit, but what do they know?
any help would be much appreciated!
dan
Old 07-18-2017 | 09:37 PM
  #187
tresean1's Avatar
dan
I can confirm 1701 will fit. See my earlier post detailing the part number and the installation.
Old 07-18-2017 | 11:05 PM
  #188
Thank you, I'll try parts dept. again.
Old 07-19-2017 | 12:10 AM
  #189
tresean1's Avatar
Here you go:
https://mbworld.org/forums/c63-c63s-...ml#post7123678
Old 07-19-2017 | 12:36 PM
  #190
msgadget's Avatar
530i, C300,
It will fit.
Old 07-24-2017 | 08:42 PM
  #191
Originally Posted by msgadget
It will fit.
thanks guys ordered from local dealer for $38 - fit perfect.
Old 07-25-2017 | 05:58 PM
  #192
CPD SLK's Avatar
2009 C63 AMG
That site doesn't even work? The "cebter" one...
Old 07-30-2017 | 09:16 PM
  #193
Abroderick's Avatar
2003 S430 4matic
Will this fit a w220?
Originally Posted by yamsta
Just to double check this will fit a W220 (2004 S500) ?
Did you find out if it fits? I have a 2003 S430 and the website says it will not fit, but other places are saying it will?
Old 07-30-2017 | 09:22 PM
  #194
Abroderick's Avatar
2003 S430 4matic
Did you find out if this fits a w220? I have a 2003 S430 and the part sites say it will not fit, but other people are saying it will? Please help.
Old 07-30-2017 | 09:32 PM
  #195
tresean1's Avatar
https://mbworld.org/forums/c63-c63s-...ml#post7156222
Old 07-30-2017 | 10:27 PM
  #196
Abroderick's Avatar
2003 S430 4matic
Ok I just wanted to be sure. Thanks!
Old 10-02-2017 | 10:11 AM
  #197
Taylorpot's Avatar
Mercedes e400 cabriolet
Black AMG Badge
I own a 2017 E400 Cabriolet with the Night package and was looking for the new all black hood badge to fit my car. Looking through the posts it appears that the P/N that fits a lot of the Mercs is 000 817 18 01 or 17 01. However, this was not a fit for my car. After doing some research, here is another P/N that fits my car as well as a number of others: 000 817 16 01.
I believe this part to be a fit for the following:
A Class : W169
B Class : W245 / W246
CLK Class : C209 Coupe / A209 Cabrio
E Class : C207 Coupe / A207 Cabrio
SL Class : R129 / R230
SLS Class : C197 / R197
SLK Class : R170
CLS Class : W219
CL Class : W215 / W216
ML Class: W163 / W164
G Class : W463
GLK Class : X204
GLE / ML Class : W166
GLS / GL Class : X166
GLE Coupe : C292
GLC Class : X253 / C253 Coupe
R Class : R251
Attached Thumbnails Black Mercedes Hood Badge P/N-badge.jpg
Old 04-07-2018 | 04:34 AM
  #198
Kevinvh6's Avatar
CLK 63 AMG 2007
If someone can help me just to make sure that the part number 000 817 16 01 is the one that i need for my 2007 CLK AMG ? Thanks a lot
Old 04-07-2018 | 02:03 PM
  #199
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
I changed mine ....all new models come std with it in Canada .I got mine in 1 day
Quick Reply: Black Mercedes Hood Badge P/N
