Should I get the C63 or the C63 S?
Tried today sport + then race mode defo sounds louder and more snap crackle n pop on down shifts
"AMG Hochleistungsbremsanlage C63...Bremsscheiben an Vorder- und Hinterachse...360mm"
My translation: "AMG high performance brake system C63...brake rotors front and rear...360mm" (including pictures!)
"AMG Hochleistungs Verbundbremsanlage S-Model...Verbundbremsscheibe...390x36mm an der Vorderachse...Dual-Cast Bremsscheiben bestehen aus 2 Materialien - Gusseisen und Aluminium - und bieten verschiedene Vorteile, wie eine Gewichtsverringerung um 50%, einen höheren Komfort beim Lenken und eine bessere Bremsperformance"
My translation: "AMG High Performance Composite-Brake-System S-Model...composite-rotors...390x36mm in the front...Dual-Cast rotors that consist of 2 materials - cast iron and aluminium - which offer different benefits, such as a 50% weight reduction, higher comfort at turn in and a better brake performance"
Page 47 of the document above:
"Abgasklappe, die je nach Leistungswunsch des Fahrers und abhängig von der Motordrehzahl elektrisch vom Motorsteuergerät...kennfeldgesteuert betätigt werden."
My translation: "Exhaust flap, that is electrical driven and computer-map-controlled, depending on mode, rpm and throttle position"
Without Performance exhaust, you still have the flap in the H-pipe, which is depending on drive modes, offering the smoothest ride in "Comfort" and the most agressiv in "Race". With the Performance exhaust, one adds two additional flaps in the rear muffler. Those can manually be opened via the push button - but the H-pipe flap remains computer controlled and dependend on the selected mode.
Just give it a try: Let someone drive your C63S. Ask him to do a few drive-by starting at 1.500 rpm in 3rd gear with full throttle (gearbox "M" AND Performance Exhaust flaps OPEN). Now do that in "COMFORT", "SPORT", SPORT+" and "RACE". Even though the exhaust flaps pushbutton light is on all the time (as you had pressed it), the sound differs a lot. For me, "Sport+" sounds the best, as "RACE" is to deep...to raspy for me.
Curious though... Am I to understand that in order to achieve maximum sound from the performance exhaust, the gearbox needs to be in "M" mode, for manual, and not "D" which will shift for you?
Also, I never have to actually press the button to open the flaps... I never drive in Comfort mode... So it's automatically always pressed.
3. Race Mode
The S offers one more mode, which the driver can select. RACE mode offers an even more aggressiv exhaust note (flap in the H-Pipe is closed all the way through the rev range). The MCT-gearbox is shifting even faster. The throttle response is even sharper. Also ESP is in "Sport Mode"
