C63/C63S AMG
Downpipe Questions
Old Apr 29, 2017 | 08:43 PM
RDO247's Avatar
C63S
Downpipe Questions
Hey everyone, I've just got a few questions regarding downpipes for those who have done these already.
I've just received my 2 piece catless downpipes back from being ceramic heat coated (black on the outside and solve inside) and just wanted to know if I can have these fitted at my local exhaust shop then drive my car 100kms to the shop that will pull my ECU for tuning?
I know catless downpipes will through a CEL but honestly I don't know what this actually means or how it effects the cars drivability.
Any help and info will be greatly appreciated...
Pictures below of pipes uncoated and coated rated to 1100+ degrees celsius.
Old Apr 29, 2017 | 09:21 PM
bgm130's Avatar
2016 C63S
Wow that looks great. No putting them in before the tune will not cause any issues. I have seen a few people that run it before the tune and it does not put the car into protection mode or anything. Simply an annoying yellow light.
Old Apr 29, 2017 | 10:10 PM
RDO247's Avatar
C63S
Thanks bgm, they look tough in black...it's a pitty you can't see them once fitted.
Insides have been done in silver which apparently will aid in flow???
So once the tune is done the yellow light will then reset no issues???
I'll post more pics when I put them together.
I mentioned in another post that if the downpipes prove to be to loud with my AWE Track Edition Exhaust I'm going to get lower pieces of the downpipe fabricated with GESI cats so I'll be able to have catless and catted.
Getting close now...
Old May 1, 2017 | 02:50 AM
RDO247's Avatar
C63S
Just a couple of pics of my downpipes...
Old May 1, 2017 | 08:10 AM
ole85's Avatar
c63s
what tune are you going with
Old May 1, 2017 | 04:54 PM
RDO247's Avatar
C63S
Either Eurocharged or International Autohaus's Evotech custom tune.
Old May 1, 2017 | 07:12 PM
Magno507's Avatar
2017 c63s edition 1 coupe
I don't see why you wouldn't just get the whole works done by International Autohaus.. +1 to them.
Old May 1, 2017 | 07:16 PM
RDO247's Avatar
C63S
I would but I'm in Brisbane and their in Sydney.
Have you used International Autohaus on your car?
Old May 3, 2017 | 01:57 AM
Magno507's Avatar
My previous car (507) they did catless LTH headers + x-pipe + filters and tune. Best money I spent.. waiting for my coupe to finish break in period so they can do the downpipes filters and tune
Old May 3, 2017 | 06:46 AM
ole85's Avatar
c63s
Are you talking about BMR in Sydney
Old May 3, 2017 | 07:09 AM
RDO247's Avatar
C63S
Nah mate, I PM'd you Allans number, give him a call he will do a custom tune on your car.
Old May 3, 2017 | 08:03 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Any figures from his tune?
Old May 3, 2017 | 08:54 PM
RDO247's Avatar
C63S
Custom stage 2 tune gives 375kw/atw and approximately 100kw/atw gain from stock.
Old May 3, 2017 | 09:18 PM
Sanch's Avatar
Very nice, there are a few custom tunes out there - City performance in Sydney also do custom tunes if you want to check them out... if you're planning to send your ECU to Sydney.
I've decided to go for OE Tune for a few reasons
1. It's slightly safer as the max power output is not as much as other tunes
2. OE is well known (internationally) and only have one authorized dealer that does it in Australia (BMR in Sydney- Lucky for the folks in Syd)
3. I've not heard of any issues with anyone
4. VIC55 - Advised he has done the OE tune on multiple cars he has owned, he has had no issues whatsoever and the tune brought out the best in each car - He also knows the owner well
Just my reasons behind my decision. If you're after MAX power HP/ KW the latter is a better option.
Here is a GTS at BMR after cat-less DP and OE tune - at the wheels
Old May 4, 2017 | 06:07 AM
RDO247's Avatar
C63S
Hey Sanch,
Whats OE advertising kw and nm at the wheels?
The graph you've posted looks like 364 kw standard with 408 kw tuned giving a 44 kw difference over stock.
There seems to be a massive difference in the base line reading from my posted graph showing 278kw to your graph of 364kw.
Ghats 86 kw difference between baseline figures, why such a big difference (both dyno dynamics dyno's)?
Ive booked my car in for a couple of dyno runs before going to stage 2, I wonder where it records compared to the above two figures???
Old May 4, 2017 | 06:09 AM
ole85's Avatar
c63s
I'm thinking of doing a tune iv currently have a akra exhaust my question is would you do downpipes with the tune or just a tune. would u feel the difference with just with the tune?
i don't want it to be too loud thats my fear
Old May 4, 2017 | 06:13 AM
RDO247's Avatar
C63S
Hey Sanch,
I'm thinking that the 408 kw is at the engine...
The dyno graph showing 375.8 kw is at the wheels.
Please correct me me if I'm wrong.
Old May 4, 2017 | 06:16 AM
RDO247's Avatar
C63S
I think down pipes add approximately 30-40hp...
Old May 4, 2017 | 07:30 PM
rickc63s's Avatar
2016 AMG C63S 2015 Porsche Macan 2014 AMG A45 Edition 1 (sold)
My ride is fitted with Weistec gears: Ecu tune, downpipe, high flow filter, VTA and large transmission oil pan.
Old May 4, 2017 | 07:32 PM
Sanch's Avatar
I think you maybe right, might have to check. Regardless this is a GTS.
It would be good to see the figures here. I'll post it up in a few weeks
Old May 4, 2017 | 07:55 PM
RDO247's Avatar
C63S
I might start a new post that members with Tuned C63's can put up their before and after dyno's so we can compare the gain in power and torque between base vs tuned figures from the different companies.
Old May 4, 2017 | 08:03 PM
Sanch's Avatar
I agree - It will also be good to see the gains the DP make with a tune and the tune by itself.
I'm not doing DP only the OE tune - I'm quite happy with the sounds without the secondary cats.
But keen to see the gains with catless DP - I think its around 20hp extra.
