ECU Relocation
Has anyone one relocated their ECU for easier access in the future?
A couple of companies I've spoken to have confirmed this can be done but Is there anyone out there that has done this?
Awesome that was what i was thinking, those damn zip ties are a pain in the butt. Thank you for posting this.
Attachment 359026
Here is a couple pictures of mine. It fits there really snug. No need for a bracket. Also there is enough slack in the harness, to reposition it here. Hope this helps.
They are up in there finally. But looking at your photo you have a lot more slack them mine. Did you do yours? If so what did you take apart in order to get more slack.
edit: Needed to cut a little off the black wire shroud bracket, once that was done there is pleanty of room. What a crappy job, i would rather have pulled the trans honestly.
I took my car to a local MB dealer and specifically to a tech that is very familiar with my car (see mods). The reason I took it in was to chase down those annoying rattles the C63S is plagued with. We found the ECU basically "loose" unsecured and making noise from vibration at the relocation on top of the engine. I mean a very noticeable rattle. He relocated the ECU to its original factory location and that did eliminate that particular noise issue.
As preciously stated this is a computer and it needs a secure permanent location that is well ventilated and properly mounted to absorb vibration. Until an improved permanent relocation method is developed I plan to stick with the original design installation.
Moved it to underneath the coolant tank near the fender well, also created an alum mount that connects to the ecu and the lower coolant mounting point. Now is out of site, mounted firm and can get to in 5mins. Finally, had to create my own solution.
Will post picsHere is the bracket with the coolant tank out of the way.
Here it is finished. Needed to move around wires till it fit with out any coolant kinky and other wires with slack. I like it better then the other way for sure, also it will say cooler here.
Can you attach them as I can't view them.
Great job job tackling this mod as I'm sure once someone releases a relocation kit there will be a lot of interest in it.
My my thoughts are that it needs to be relocated to somewhere unseen so not noticeable when going for a basic service.
Get those pictures up.
