C63/C63S AMG
KW V3's Installed - C63 S Coupe
Old May 17, 2017 | 10:48 AM
nl88's Avatar
C63
Originally Posted by JPMBenz
First let me compare the stock suspensions. The stock sedan suspension is much stiffer then the coupe even with the 19"/20" wheel setup. I originally has Dunlop's on my Sedan which I eventually changed to Michelin's. This did help but very little. I believe part of the better ride has to do with the different setup of the coupe.
Being in the NYC/NJ area anything will ride harsh. My coupe is my daily driver so yes I would say to that. The KW's V3's aren't cheap but you get what you pay for.
the suspension for the sedan is really stiff for my liking.
If i were to rate the stock sedan suspension stiffness 8/10, What would u estimate the V3s to be rated ?
Old May 17, 2017 | 05:09 PM
JPMBenz's Avatar
17 C63 S Coupe
Originally Posted by AV1
I thought so, I believe I remember seeing a BMW M135i almost 10 years ago on the 1 addicts forum with this set up so they do exist, you just need to do a "neat" install of the operating button.
This would great if made for current AMG's as you then have the freedom to adjust from within the cabin just like stock OEM.
If that is what you are truly looking go then go for it! I never put my car in any setting because it was to stiff.
Old May 17, 2017 | 05:11 PM
JPMBenz's Avatar
17 C63 S Coupe
Set to "3" out of 5 on the shocks; I would rate the KW's 4/10 in terms of stiffness.
JPMBenz's Avatar
17 C63 S Coupe
My WCW...
Old May 17, 2017 | 05:14 PM
JPMBenz's Avatar
17 C63 S Coupe
I purchased my V3's from iND. Contact them if you are looking for a set. ;
Old Dec 24, 2020 | 10:21 AM
Chrlzamg's Avatar
c63s cabriolet
Greetings!
I know most might be running the HAS for the C/W C63 S vehicles. This weekend I installed the full KW V3's on my car. I have to say that I am very impressed with the improvement of the quality of the ride. The car not only is smoother over the road but looks so much cleaner lowered. I am tossing the idea around of spacers but not sure yet. I do have a 295 tire mounted on rear. Feel free to ask questions. I attached pictures.
JP
are you maxed out on the adjustement? id love to run the V3 but your pic doesnt seems low enough for me, id drop atleast 1/2inch more ...
can you go lowerr?
Old Dec 24, 2020 | 10:43 AM
  #32
untamedd's Avatar
2019 AMG GT R
is it possible to lower the car just from the rear? I think from the front mine just sits perfect right now with the lip and any lower would cause contact occasionally.
Old Dec 29, 2020 | 04:53 PM
  #33
Barbalatte's Avatar
C63S
I've owned a few sets of KW V2s. They are great units. One was for a Audi S3 and the others for an Alfa 147 GTA.
the V2 ans I would say the V3s are fully adjustable. So yea yiy can adjust just the rear of you like independent from the front or each corner of that's what you're looking for.
JP do you have a link to where you bought yours?
Also ste your rims stock? 19s or 20s?
Old Dec 29, 2020 | 04:56 PM
  #34
tobeit's Avatar
AMG C63s
Guys a
a) that OP thread was dead since 2017 - doubt anybody from the original thread will respond
b) dont lower just the rear...your car will be squatting - cant be a good thing not just for looks but also for handling.
Old Dec 29, 2020 | 04:58 PM
  #35
Barbalatte's Avatar
C63S
Originally Posted by tobeit
Guys a
agree also on both points!😆
