Dime Racing Carbon Fiber Airbox System Release
It's such a beautiful piece of equipment... I just hope it was an accidental omission and that they share their R&D numbers and drop the price to something reasonable. I really do wish the best for them and all other vendors. I hope they all learn something from this thread. THAT'S how the aftermarket will develop for this platform, in my opinion.
What this means in terms of construction is aerospace prepreg carbon fiber, billet aluminum inserts, molded rubber couplers (not typical silicone), hand layup and all the things that come with using prepreg carbon.
One forum member mentioned seam lines and pressure damaging the box. These boxes in total weigh under 3 pounds and you can easily put 200 pounds of weight on top of them.
What this means in terms of design is, countless hours of testing in a computerized environment and in the real world. The best and most trustworthy results are third party results, not our shop car throwing up a number.
These airboxes are installed on many customer cars, and those customers are seeing very fast 60-130mph times. And one forum member and customer recently ran a 164mph in the half mile. This is the fastest mph for a M177/M178 powered car at the moment.
We hope this helps. Thanks again.
Dime Racing
We have graphed data on our website to show the difference in intake temperatures. We don't want to derail this thread with cooling system information, so we can PM you information on it. Thank you.
Dime Racing
"30HP or more depending on modifications, and consistent drops in intake air temperatures" 30 HP with upgraded turbos and the entire Dime product catalog? 20 HP with tune? 10 HP with stock tune?
You said this airbox weighs less than 3lbs, so what kind of weight savings are we talking over the stock plastic box?
If you're asking $4,000 for an airbox, it should not be up to a third party to verify the power... it should be proven before you buy it. No one in their right mind is going to throw down that much cash without knowing what they're paying for, unless they're getting it heavily discounted through a sponsorship/promotion.
" customers are seeing very fast 60-130mph times " and the times are?
" And one forum member and customer recently ran a 164mph in the half mile. This is the fastest mph for a M177/M178 powered car at the moment. "
- You make it sound like that's all due to your Air box system! What else is under the hood?
- Its not about you throwing up a number, its about you backing up your claims. Clearly they have no plans on posting any credible information regarding their product.
I'm Out! No Thanks!
I'm Out! No Thanks!
here is the cooling upgrade thread. The claims are extremely similar in both of these threads. Dime tries to sell you a cooling upgrade that is fairly expensive yet cannot show how it actually upgrades the numbers. They also failed to show that there is a true necessity to upgrade the parts. I'm seeing the same exact thing in this thread.
I could see upgraded numbers with an intake system on a system running the upgraded turbochargers. However we aren't shown any data whatsoever.
And the graphed data on your site is rediculous. An intake temp of 140 at the highest graphed point(which is only for a brief moment) is hardly an issue with the car. Let alone one needing a 4k solution.
Its up to the maker of the product to prove the product they're trying to sell is worth buying, even if it is overpriced. Not some other random company or person. Just shows me you are not confident in your own product if you won't share your own numbers. You should also be concerned with where your competitors are pricing their products. It's called the going market price. Good indicator of what people will pay.
This didn't need to be a bash fest but you brought it on yourself. Yes I'm being harsh. No I don't feel bad. Come out with complete product info and the car guys will
leave it be.
Just put out more info on it so we have a full picture.
Mods:
CF Air boxes
Divorced Cooling Upgrade
Upgraded turbos (impeller and compressor)
downpipes
Michelin PS 4S tires.
I haven't dyno'd the car yet but I drove this setup for two months with everything minus the CF air boxes, then when i did upgrade the boxes, the high RPM gains were VERY noticeable.
I will dyno with stock boxes and CF Dime boxes eventually and post the results.
Doug
Mods:
CF Air boxes
downpipes
Doug
That said, I'm pretty sure that much airflow is only needed if you're stage 3 with upgraded turbos. Stage 1 is probably fine with stock intake, stage 2 probably benefits from upgraded filter. That's basically what it comes down to.
2 or 2.5k count me in!
Dime Racing
I know that that all the current intakes are already spoken for, but Steve promised to loan me one that I'll get to "try" once they have a spare piece. Maybe I'll pull the trigger then, until then, I can only envy Doug's car.
Modifications on the car were:
ECU Tune
Catless Downpipes
High Flow Air Filters (stock boxes)
We simply swapped the airboxes. You can see where the airboxes really shine. On a stock turbo car, the turbos start to run out of steam past 6,500rpm which is why there is a slow drop in power.
We hope this gives some clarity and thank you all for chiming in.
Steve @ Dime Racing
