C63/C63S AMG
More info on race mode
Old Jun 16, 2017 | 02:50 PM
digitalnav's Avatar
C63S Sedan
Is it delivering more power than Sport+?
I have individual sent to Sport+ with suspension in sport regular and auto shifting.
Is there a way to set individual to race power with auto shifting?
Old Jun 16, 2017 | 06:08 PM
SuperNik's Avatar
W205 C63S AMG
I'm sure someone has posted dyno results showing race has the same power output as sport+.
The difference might just be in throttle response and gearbox settings.
I spend 95%+ of my time with my individual set up as engine in race, suspension in comfort(equivalent to sport due to kw has), manual shifting and esp fully off (to save on rear brake pads).
Curreny having to change rear pads every 12k miles. I'm waiting on my delivery from porterfield at the moment. Hopefully they'll be a little better.
Old Jun 16, 2017 | 06:21 PM
Biggiie's Avatar
C63 AMG edition 1
Hello there
Just wondering if the button still works with KW HAS?? Cause the suspension in mine is rock hard, it'll either break me or itself.
And how comfy does it get with an aftermarket suspension?
Cheers, Morocco
Old Jun 16, 2017 | 06:32 PM
SuperNik's Avatar
W205 C63S AMG
The suspension is still adjustable but the springs are stiffer than standard. Comfort has become sport. Sport has become sport+ and so on. I found the standard suspension was a little soft for me and caused understeer. It has better turn in now. It's very personal. I know quite a few people have complained that the standard suspension is too stiff. I drive mostly with the esp off so I prefer the feedback.
Old Jun 16, 2017 | 06:33 PM
SuperNik's Avatar
W205 C63S AMG
Is yours a sedan or coupe?
Old Jun 16, 2017 | 08:45 PM
Biggiie's Avatar
C63 AMG edition 1
Thanks maan
Old Jun 17, 2017 | 12:43 AM
Edition1JPA's Avatar
C63 W205 Edition 1
Race mode has more HP than Sport+
Since my most recent ECU update race mode also has changed the sound of the vehicle... closer and better than the sound after the second update.
Old Jun 17, 2017 | 06:02 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
Have you confirmed that on a dyno? What's leading you to say race mode has more HP. Seems odd.
Old Jun 17, 2017 | 10:54 AM
C63 W205 Edition 1
Confirmed on the Dyno. I would attach the file, but I only have the run files and Dynojet doesn't have a mac friendly Dyno run viewer. I will as a friend to pull the two runs on to the same plot...
If you want to see how it did in race mode against a tuned M3, the plot is attached.
Old Jun 17, 2017 | 11:36 AM
hotdognobun's Avatar
C63S Coupe/CLA45
Why not just test with the onboard dash that shows rev, speed, HP, Torque, etc? Wish I could but still in breakin. I would think sport+ and Race are same except Race enables manual shift while sport+ Is still auto? Just can't wait to push it
Old Jun 17, 2017 | 11:41 AM
C63 W205 Edition 1
Don't have that screen in the 2015.
You can run manual shift in any mode by just selecting it and vice versa, you can run race mode in auto... which actually does a really good job and the down shift sound amazing when hard on the brakes.
Race mode has 15 more HP and I would love to tell you the torque but we couldn't get the single off the coil pack that day.
And I wouldn't follow any break in protocols... Useless. It's an AMG! Drive it like you stole it.
Old Jun 17, 2017 | 01:03 PM
fresnobrianb's Avatar
2005 C230
+1
Old Jun 17, 2017 | 01:13 PM
C63S Coupe/CLA45
Hey don't tell me that I've been suffering driving under 80mph here in San Diego where minivans fly by me at 90mph. Guess at 800miles it might be time to release the rage
Old Jun 17, 2017 | 01:54 PM
auditoamg's Avatar
C63s
This car sounds like a cracken.....
Release the cracken!!!!
Old Jun 17, 2017 | 09:00 PM
C63 W205 Edition 1
I commend you on your willpower! You're a better man than I am!
But seriously... that's what warranty is for. Give that thing a little throttle. I was pushing just over 120mph on the second day.
Old Jun 18, 2017 | 07:50 AM
-krikke-'s Avatar
C63 S Coupe
If I am not mistaken Race mode:
​​​​​​- gives sharper throttle response
- stiffens engine mounts
- needs manual shifting
- disables ESP more (but still not completely off)
- uses even more sportier ECU behavior than Sport+
Please correct me when wrong.
Old Jun 18, 2017 | 10:39 AM
RDOCA's Avatar
2016 C63S Sedan
You do not need to put it in manual shifting but it will not shift till red line.
You can just use the paddles to shift early in normal driving and it will shift down OK.
Old Jun 19, 2017 | 09:34 AM
zdonner's Avatar
2015 C63S
FYI - The Display on the dash that tells you HP/TQ is completely fabricated and is only for show, do not trust such a thing. It's a parlor trick for you passenger(s).
Old Jun 20, 2017 | 01:47 AM
2005 C230
its just a function of rpm
Old Jun 20, 2017 | 11:48 AM
MattyMacro's Avatar
2017 C63S AMG Coupe
Sport+ and Race put down the same amount of power; power delivery (wg duty %, boost/timing advance in relation to rpm) is consistent accross both modes, too.
I dyno'd my car using Sport + then Race, back to back due to my curiousity as well. They put down the same power/tq with the delta looking identically linear as well.
I'm guessing the changes are in throttle response, possible trans changes and changes in traction logic.
Old Jun 23, 2017 | 02:58 PM
power-technik's Avatar
2017 c63r edition 1
I have dynoed my car countless times. Stock and tuned. I haven't seen any diff in power between S+ and Race more. Purley traction control aggression and shift strategy.
Old Nov 28, 2019 | 06:33 PM
ShaneN.'s Avatar
2018 e63s edition 1
That is the reason I've been driving in sport traction setting since I got the car, because I picked it up with 11k miles and the rear pads were already almost done. However I just realized that every time the traction light flashes on the dash in sport, traction is still intervening( I believe) . I had thought it was more like a past car where it'd only intervene in sport traction when the car got too sideways. I'm tempted to drive with it fully off for now on.
Old Nov 28, 2019 | 07:32 PM
ShakyTom's Avatar
C43 AMG Coupe
Is there a difference between comfort and s+/race?
Old Jan 6, 2020 | 05:39 PM
rroberts's Avatar
C63s coupe
Modes
There is a very noticeable difference between Comfort and Sports+ modes. I have Individual mode set up as Sports+ but with the Performance Exhaust turned off (to drive in stealth mode and not attract police attention).
My car has only been in Race mode once or twice when I accidentally shifted into it, and then quickly shifted out. One of these days I will play with that but Sports+ seems to handle my driving needs (Autobahn vs drag strip).
Good a place as any for two stories, both related to my taking Euro delivery on my current AMG.
I obeyed the break in instructions until 1,800 kms (1,100+ miles), only increasing gradually after 1,500 kms. Then I was on the perfect road doing 130 kpm (multi-lane autobahn toll road, almost empty, apparently just opened days before) and a BMW M4 came up fast behind me, slowed to look me over, and took it back up to what his speed governor probably allowed (250 kph). I followed, caught up, and passed him doing 260 kph (160+). No drama, the AMG was rock steady. My lady friend was oblivious to all of this, engrossed in the music she had playing.
A week later, we were driving through southern Sweden and pulled off to get gas and coffee. I noticed a number of BMWs also gassing up but did not think much about it while we went inside to get coffee. When we came out we were surrounded by BMWs (30+ cars), with many people interested in my car. It was club event and a number of people asked to hear my engine with the Performance Exhaust option, apparently an option not available on cars sold there. I gave them what they wanted, complimented a couple of them on their after-market additions, and we left. Soon after we passed two cars pulled over by the police (the only ones we saw in all of Sweden, so possibly targeting the club event) and I made it a point to strictly obey the posted speed limit.
