C63/C63S AMG
Edition 1 rear diffuser install question
Old 06-29-2017, 09:37 AM
Vassago's Avatar
2017 C63s Coupe
Question Edition 1 rear diffuser install question
Has anyone here replaced the standard rear diffuser on their c63s/c63 coupe with the edition 1 version? If so was it a straight bolt on or was modification needed. I am guessing it wouldn't need any major modification since its an MB part but just curious since i see the front spliter needs holes drilled apparently for install.
I have seen the thread where a gentleman replaced the stock diffuser with an aftermarket version. In his thread he removed the complete diffuser and replaced with the new one. On the Edition 1 duffuser you have to separate the standard rear diffuser since its two pieces and then reinstall with new lower part.
Old 06-29-2017, 01:18 PM
Vassago's Avatar
2017 C63s Coupe
anyone
Old 06-29-2017, 07:49 PM
Sanch's Avatar
AMG C63s
I cannot say yet... but i plan on ordering one too!
Old 06-30-2017, 07:48 AM
ole85's Avatar
c63s
whats the difference between diffusers
Old 06-30-2017, 11:20 AM
Vassago's Avatar
2017 C63s Coupe
The Edition 1 diffuser is a little more aggressive with a lower diffuser that runs below the 3 vertical fins.
Old 06-30-2017, 11:59 AM
amgpwr_c63s's Avatar
2017 C63s Coupe
would anyone happen to have the part # for the edition 1 diffuser?
Old 07-01-2017, 08:26 AM
Vassago's Avatar
2017 C63s Coupe
Working on the parts numbers now with msgadget from OE Discoint parts.
Old 07-04-2017, 03:44 AM
Sanch's Avatar
AMG C63s
I would be keen on part number too!!!
Old 07-04-2017, 10:12 AM
Vassago's Avatar
2017 C63s Coupe
As soon as msgadget from OE Discount parts gets that info I will be sure to share. My edition 1 front splitter arrives tomorrow.
Old 07-04-2017, 02:27 PM
Alex98's Avatar
2017 C63S Coupe 2018 Ford Raptor 2017 Corvette Z06 2013 Mercedes C63 2012 Mercedes C63 BS
I don't know if this goes for everyones car, but mine has the carbon fiber pack spec and I personally tried to install the OEM ed1 rear diffuser, took it to 3 shops one being Mercedes Benz itself and none of them felt comfortable doing it because the 3 pieced plastic fin OEM part is glued and bolted to the gloss trim and carbon fiber part. I'm still waiting on if there is actually a way on how to do it.
Old 07-04-2017, 04:30 PM
Vassago's Avatar
2017 C63s Coupe
Interesting, that must be a carbon fiber thing cause this thread showed them being removed with no bolts or glue. Just tabs and 4 rivet points. I know this is for the 4 door and not the coupe but I find it hard to believe that MB changed it since the parts are identical. Checkout the below thread. BTW what did you do with the OEM diffuser parts do you still have them?
https://mbworld.org/forums/c63-c63s-...l-install.html
This is the best post so far for diffuser removal I have found so far.
Old 07-04-2017, 07:15 PM
Alex98's Avatar
I have the coupe, and I was never able to get them off properly so still have the OEM parts on for now.
Old 07-04-2017, 07:57 PM
Vassago's Avatar
2017 C63s Coupe
What did you do with the Edition 1 rear diffuser parts? Are you looking to sell them?
Old 07-04-2017, 10:01 PM
Alex98's Avatar
They were actually done in carbon fiber and I was supposed to be test fitting them, Waiting on updates for install instructions.
Old 07-05-2017, 08:46 AM
Vassago's Avatar
2017 C63s Coupe
were you working with Euroteck racing?
Old 07-06-2017, 09:56 AM
Vassago's Avatar
2017 C63s Coupe
Ok here are the part numbers for the Edition 1 rear diffuser. We owe msgadget a BIG thank you for all her hard work on sourcing these parts and numbers for us.
#75 2058853002 & 2058853102 $110.00 each
small trim pieces You need 2 for left and right
#70 2058804204 $294.00
Three fin diffuser
#72 2058804104 $300.00
Bottom plate
msgadget (07-17-2017)
Old 07-06-2017, 10:05 AM
Vassago's Avatar
2017 C63s Coupe
Three fin diffuser
Bottom plate
Here is a diagram for reference.
Old 07-13-2017, 09:55 AM
Vassago's Avatar
2017 C63s Coupe
Rear diffuser is installed and it was easier than first thought. The new edition 1 diffuser actually goes right over top the original part. It then attaches with screws and uses the same tabs that the metal trim on the diffuser that runs across and under exhaust use. On note you will have to remove this trim piece which is not hard at all, if you have some patience and body panel tools (not 100% necessary though). Now the diffuser in the pics below are not genuine MB but the company which will be named later made exact copy's of the edition 1 diffuser parts and this was the first car they have been installed on. I was the test dummy for the company and all you guys. I think it looks great and the fitment was dead on. Sorry for the crappy pics.
Old 07-13-2017, 09:55 PM
Vassago's Avatar
2017 C63s Coupe
Company name for this diffuser is http://www.euroteckracing.com/ It is an exact copy of the OEM Edition 1 diffuser.
Old 07-13-2017, 10:08 PM
Alex98's Avatar
I know what company it is because I had that same part before you just couldnt get it on properly. Mind PM'ing me details on how exactly you did it?
Old 07-24-2017, 05:33 AM
ole85's Avatar
c63s
i bought the parts listed on this forum thinking it was carbon fibre but it was plastic in prima which needs to be painted.
is the aftermarket carbon available, i keep trying the web site euroteck but i can't seam to find it on the website
Old 07-24-2017, 06:15 AM
DragonRR's Avatar
911 991 TTS, Audi RS6 C7 Performance Edition, AMG GTS
Have you thought about getting the Edition 1 side skirts Vassago? I'm not sure if you have to get the entire bottom side panel or just the black fins though.
Old 07-24-2017, 07:02 AM
Vassago's Avatar
2017 C63s Coupe
I was the test fitter for Euroteck racing, I would suspect that the parts should be available in a couple weeks. Everything went well with install so I think it should be soon.
Old 07-24-2017, 07:06 AM
Vassago's Avatar
2017 C63s Coupe
I did look at them and thought about it, but my wife already hits the ones I have now when she gets in and out. Hell i even hit them sometimes so I'm not sure if I want something that sticks out further. I believe it's just the black insert that you have to get and I'm not even sure how they attach. If I had to guess I would say screws from behind and 3m tape like everything else. Although the front chin spoiler and rear diffuser only use screws for attachment.
Old 07-24-2017, 07:52 AM
DragonRR's Avatar
The wider ones are a bit easy to catch. I had mine wrapped in clear film when I had the front of the car protected. Seemed to do the job
Quick Reply: Edition 1 rear diffuser install question
