C63/C63S AMG
[Help]Engine oil notification
Old Jul 24, 2017 | 01:29 AM
Jinggyjin's Avatar
C63S
Hope everybody had a wonderful weekend.
When I was driving in sport+ this past Saturday with engine warmed up, a notification popped up in the middle screen telling me "engine oil low, add 1 quart engine oil".
After seeing this message, I'm confused since my car only has 1300 miles on it, and I think the first oil change should be at 10k miles. After I parked the car for like 10 minutes, I restarted it and there is no message about engine oil at all. I then went to the service page, hoping to retrieve that message but there is absolute nothing..
Now I'm not sure if this is just a typo message sent by the system.. Anyone also experienced this kind of problem? Should I bring the car into dealership to have it looked at?
Thanks!
J
Old Jul 24, 2017 | 02:12 AM
weboperations's Avatar
2016 C63S AMG
Literally word for word from the owners manual..
“Depending on your driving style, the vehicle consumes up to 0.9 US qt (0.8 liters) of oil per 600 miles (1,000 km). The oil consumption may be higher than this when the vehicle is new or if you frequently drive at high engine speeds.“
its the the first sentence under the Engine Oil section.
So in other words, I wouldn’t worry at all. Check the physical dipstick and add oil as necessary.
Old Jul 24, 2017 | 02:57 AM
RDO247's Avatar
C63S
Thanks!
J
This happens in my car a couple of times a year and just popped up this afternoon.
I just drop in to the service centre and they check the level.
Its never been topped up on return to service centre.
Gets annoying but more annoying to the service centre when they have to check it all the time then explain nothing needed be done.
Old Jul 24, 2017 | 11:56 AM
RDOCA's Avatar
2016 C63S Sedan
Thanks!
J
I have about 10k miles on mine and today it happened for the 3rd or 4th time since i have owned it.
I just check the dipstick myself and it is always full so it is just a sensor I guess.
It has never used any oil.
Old Jul 24, 2017 | 11:57 AM
J.M.G.'s Avatar
'17 C63S Estate (S205) / '14 CLS 550 SB (X218) / '17 E220d (S213)
My c63s was also asking for oil. As in your case, there was neither a message after engine restart nor did the dipstick show any oil consumption. The dealership replaced under warranty a sensor. The problem never came back...
Old Jul 24, 2017 | 12:28 PM
Jan AMG's Avatar
The best or nothing
Totally normal. Just carry some oil in the trunk
Old Jul 24, 2017 | 12:40 PM
J.M.G.'s Avatar
Just make sure, that the car DOES burn oil! In my case, I got the warning message when the car did not burn oil. If one adds up some oil, one runs in significant problems, as too much oil will damage the engine.
So please make sure to use the dipstick prior adding oil!
Old Jul 24, 2017 | 12:42 PM
Jan AMG's Avatar
The best or nothing
Good point. Thanks!
Old Jul 24, 2017 | 01:06 PM
CT-AMG's Avatar
AMG C63S
Happened to me as well. Seems to be very common.
I brought it in and they also replaced a sensor under warranty and it hasn't come back, but its only been about a month so, too soon to tell..
Also, it wasn't down any oil when dipstick checked so it has to be the sensor.
Old Jul 24, 2017 | 02:56 PM
Jinggyjin's Avatar
C63S
Guess I will just bring it in later to have the sensor looked up.
Thanks!
Jacob
Old Jul 25, 2017 | 07:00 PM
pghc63's Avatar
Too many
never owned an AMG that did not burn oil
some every 2000 miles , others around 5-6 k miles
been told multiple times that it was normal
I just keep Mobil one at home
Old Jul 25, 2017 | 10:34 PM
RDOCA's Avatar
2016 C63S Sedan
this is a new engine and it seems not to use much oil.
I have 10k and no use at all.
Old Jul 26, 2017 | 12:23 AM
digitalnav's Avatar
C63S Sedan
I just keep a quart in my trunk
Old Jul 26, 2017 | 06:52 AM
tekfoc's Avatar
Veteran: Army
18 E63S
My first AMG Did not burn a drop in the 3 yrs I had it.
My AMG AT THE MOMENT also doesn't burn a drop.
Old Jul 26, 2017 | 11:38 AM
1 SIC DR's Avatar
2017 Benz C63S Coupe
What oil do you guys keep in the trunk ? What grade ? I'm too lazy to look in the manual
Thank you
Old Jul 26, 2017 | 11:45 AM
RDOCA's Avatar
2016 C63S Sedan
Thank you
0W40
Old Jul 26, 2017 | 12:02 PM
2016 C63S AMG
They sell it at walmart.
Old Jul 26, 2017 | 12:57 PM
Jan AMG's Avatar
The best or nothing
229.5 spec (0W-40 Mobil or Mercedes OEM is a sure thing)
