C63/C63S AMG
Future C63 Owner checking in
Old Jul 30, 2017 | 08:23 PM
ai3j50's Avatar
Hey guys. I'm new here. I'm looking to get into a 2015 C63 Coupe at the top of 2018 and joined here to do some research. I look forward to joining the MB club.
I do have a first question, not sure if this is the correct section to get the proper eye on it though. While shopping for a C63 Coupe how can I tell if it is an S besides the red calipers? Is there a way to verify using the VIN?
Thanks guys!
Old Jul 31, 2017 | 12:57 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 AMG forum...
Old Jul 31, 2017 | 01:25 PM
Mikey_boy's Avatar
2017 C63s Sedan | 2016 Yukon XL Denali
I used THIS site when shopping for new to see what options, colors, etc. cars had when pictures weren't posted. Pretty handy tool and the only site I've found that really gives everything.
Note that you can only do three checks/day, but if you have more than one computer....
Old Jul 31, 2017 | 04:53 PM
Trim105's Avatar
C63S Coupe/Range Rover Vogue SE
Thanks guys!
Welcome to the forum! and great choice going for the C63 coupe, you won't be disappointed.
I think you've mixed the model years up though. If you're looking for a C63S coupe then its the 2016/17 C205 C63 coupe you want.
Without having to check the VIN, the external differences are:
The 'C63s' badge
The front A-wing (section around the front air-vents) is body-coloured on a base C63 but black and chrome on an S (unless it has the night or carbon pack then it will be all black or all carbon).
The brake rotors on an 'S' don't just have red calipers, they're also larger and have a different perforation pattern than the standard C63 brakes.
Here are links to the official AMG webpages of each:
http://mercedes-amg.com/c63c.php?lan...erview_section
http://mercedes-amg.com/c63cs.php?la...erview_section
Old Jul 31, 2017 | 11:48 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
1) Performance exhaust
2) 19/20 wheels
3) Bigger red caliper breaks or optional carbon ceramics
4) Rear badge with C63's'
To answer your question, yes you can use the VIN to identify each vehicle made. I'm not sure where though... I'm sure someone could shed some light on this.
Old Aug 1, 2017 | 10:41 AM
See63esS's Avatar
2019 Audi SQ5, 2011 Toyota Tacoma TRD 4wd, 2016 Ford Focus se Hatchback
2) 19/20 wheels
Race Mode
Old Aug 1, 2017 | 02:23 PM
brad65ford's Avatar
2020GLC63
believe eletric diff as well, someone correct me if i'm incorrect.
Old Aug 1, 2017 | 11:18 PM
MarkC63's Avatar
2016 C63 Wagon
Other visual differences that cannot be optioned include:
- color coded center strip and alcantara on the steering wheel
- color coded bit on the door cards
- red accent around the speedo and rev counter
Old Aug 2, 2017 | 01:41 AM
Mikey_boy's Avatar
You are correct. Also the dynamic motor mounts.
Old Aug 2, 2017 | 01:40 PM
ai3j50's Avatar
The 'C63s' badge
Thanks for all the response and info guys. Very helpful. So the C63 S was introduced in 2016? Was Race mode available on any 2015 models?
