Active sound module
munis (03-26-2018)
It just plugs in to the white connector under the boot floor, just unplug and plug inline the box and away you go. Press button 1 gives you 100% open valves always loud and remembers once engine is turned back on until you press button 2.
works well sound is good not much else to say.
There is a company that does the same unit asr-components web site www.asr-component.de
I have there unit on my car works very well you can have it fully open, normal (button works as normal) or closed all the time just opens fully at 4,000 rpm controlled with remote control and plug and play no wires to cut.
It cost was 299€ plus post and packaging.
2021 Mercedes C63s AMG Coupe
Cant wait for mine though, if I just delete the res, I will basically have a straight pipe now.
#44
Ok I have the C63s coupe model year 2017 with the sport exhaust, which one would I buy? Also says not to install in trunk, where the hell would it go? Also do they have install instructions in English (PLEASE) Usual suspects quote HAHAHA.
#47
What more examples do you need? Just go to your car and do a cold start (as then the valves are open for a short time). Now imagine to have that same sound volume and loud v8 burble everytime you aren't driving WOT. Easy no?
#50
