Active sound module
Again, don’t do this unless you have exhaust valve simulators. This is why they exist.
I actually have a set of the AWE simulators in case I ever wanted to drop the OEM catback for the drag strip. I paid around $60 shipped for them last year. I didn't realize the valves opened up 100% when the car was off, I just checked for myself and confirmed they're wide open.
I will try installing the AWE valve simulators tomorrow and see if it keeps the valves open without any issues since I already have a set laying around. I'd still like the ability to revert back to the OEM controlled exhaust, but in reality I drive around with the exhaust on 99% of the time anyway... so this may be a cheap, temporary way to get the same effect as the ASR!
Now, it definitely works and there are no visible errors on the dash. That said, I feel like there is loss of power, especially at the high end of 2nd gear... it might just be in my head though... try it out and let me know what you guys feel... It literally takes 5 minutes to do.
Dude no no no no! Why did you do that for? You think no one else thought of this simple idea? You just threw the car into soft limp mode and it is a ***** to get rid off. Soft codes would not trigger CEL but it is saved in the memory now. You need XENTRY to clear this.
Also the power loss is not in your head. There is an actual powerloss. Go to the Dynamic select menu and toggle to engine data. You will see your car is not making more than 250hp and 250lbft of torque. Which will still feel fast.
You will think we just wanted to blow 400 dollars when all we needed to do is unplug the valves!
And... I'm not one to trust anything anyone says on the forums, I like to try it myself. So kill me haha. I'm sure you see people on this forum blowing hundreds of dollars everywhere for no reason (air intake spacer haha). Glad you guys are looking out for me though.
Oh, the other benefit from doing my dangerous experiment is that I got to hear what 100% open valves sound like before "blowing $400"... AWESOMMMEEE. 😂 I'm on the GB list!!
I'm still planning on getting the ASR module because I'd like to be able to switch back to using the OEM exhaust button, but this is a great mod for people that don't care about switching and just want loud ALL the time.
Check it out: https://mbworld.org/forums/c63-c63s-...imulators.html
These are the same simulators used for the F80/F82 M3/M4, Audi S3, S6, S7, Porsche Macan/S/Turbo, Golf R...
You just plugged both simulators in, and then disconnected the exhaust valve control module in the trunk?
Skim, yes you're correct. Unplug valve motor at exhaust and plug simulator into body side harness. Wouldn't think you would mess with anything in the trunk, as the simulators are mocking the signal sent from OEM valve motors to ensure the ECU is happy. Ensure to re-secure all wires and cover open valve motor plug with electrical tape.
I'm actually thinking about buying a 3rd valve simulator and installing it on the H-pipe to keep it forced open, I'm curious to see how significant the difference is with it forced open. I'm just not sure if the H-pipe defaults to 100% open with the car off like the rear valves do and since I can't check it visually, I'm a little bit weary. Nonetheless, I think this may be something I'll be trying soon, because I have a sneaking suspicion it will increase the overall noise even more. Of course if someone wants to be a guinea pig and try it... go for it!
I don't have a lift and there's no way I can fit down there to get that valve... rather pay a few hundred bucks for the module if this is the case haha...
I guess I can try installing a simulator on the H-pipe since there isn't really any risk of damage if it's forced open or closed (unlike the rear valves). The H-pipe is more so for sound, rather than flow.
Let us know how it goes!
The install took me 15 minutes (removing trunk bottom + installing the unit and putting the trunk floor back in place). Very easy job.
I am quite happy with the results as there is definately more grumble while driving at lower revs. When driving with the windows opened you can definately hear the difference. It's also very noticable while driving in streets that are full of houses/buildings (city streets) as the sound reflection against the facades is a good amplifier.
Please note that the added sound volume is most hearable by the outside. While driving there is a bit more volume inside the interior but not much more compared to stock. I wish these cars were less isolated in the interior so the driver would also have an easier way to enjoy the added volume.
I am very happy with this mod and imo its definately worth it!
Will definately be interested in a video with the combo Asr + secondary cat delete!
