C63S Replacement Rotors
The following 5 users liked this post by BD-C63:
boosteddub69 (02-02-2019),
Jimmy_c63s (12-21-2019),
KAHBOOM (06-06-2019),
Ksun_w205 (06-18-2020),
See63esS (04-30-2019)
#77
E63 (non S) and C63 (non S) using same calipers?
Hi guys,
There’s some really useful info on this forum. Thanks
If I understand correctly FCPEuro and RB mentioned that the C63 caliper (360mm front) will also fit an oversized 390mm rotor without any modification?
Sorry I posted this in the C63 forum as I know US doesn’t sell E63 (MB USA only brings in the E63S)
I have a W213 E63 (UK spec) that is non S and it comes with silver calipers, compared to the S which comes with red calipers and 390mm rotors. I was looking at whether I could just upsize to a 390mm rotor using the silver calipers, rather than replacing the entire kit ...
#79
2015 C63S AMG
Stock replacement rotors for C63S
Front:
https://www.racingbrake.com/RB-2pc-R...E63-p/2237.htm
Rear:
https://www.racingbrake.com/RB-2pc-R...E63-p/2357.htm
Combo rotor kit (Front & Rear)
https://www.racingbrake.com/RB-Iron-.../mb-irk-12.htm
In stock.
Front:
Rear:
In stock.
#80
Former Vendor of MBWorld
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/600x287/rear_pad_for_s63_65_rb__bbc2c3c0aa9ce924f2675b89f3aca8ff4add937a.png)
///Bruce (12-18-2021)
#81
Getting my car serviced currently and the dealer called me saying my brakes are getting close. About 6mm in the front and 5mm in the rear. I was quoted $2k for rear replacement and $3k for front replacement. I'm assuming that also covers the rotor since there's no way pad replacement should cost $5. I'm definitely going to be shopping around.
#82
'15 C63S
As for the price quotes, the $3K for the fronts doesn't sounds all that unrealistic, but the $2K for the rears is highway robbery.
Doing a quick search for parts, The front rotors are $2,360 for both rotors ($1,180/piece), and a set of 4 pads is $430, bringing the total parts cost for the fronts to $2,790. The rear rotors are $334 for both rotors ($167/piece), and a set of 4 pads is $376. Should be $710 in parts. Go to https://www.mbonlineparts.com/auto-p...nt-brakes-scat and https://www.mbonlineparts.com/auto-p...ar-brakes-scat to look at the prices yourself. The rear brakes are identical across all C63 trim levels, even those with the CCB brakes.
texasmade (03-25-2019)
#83
call Racing Brake for rotors and get them put on with new pads by independent or mb dealer if you don’t mind paying their labor costs. They have a better rotor than mb factory. Lighter weight. they have slotted rotors with holes drilled in the slots vs lots of holes all the way around rotor which takes away from the contact area for the brake pad. I am a track guy so that is important to me as well. If you want good stopping power for street or light track , put Stoptech sport pads on front and factory on rear. Stoptech 600 high temp fluid.
#87
https://www.fcpeuro.com/products/mer...304211212#desc
Are this disk`s fully compatible with 2017 W205 C63S as a direct replacement ? Do you ship to EU ?
#88
1 Post
'16 C63S & '18 GLE 400
Hey Guys,
Just a heads up for users trying to navigate what do to. I've got a '16 C63S that I drive all year and track 2-4/times/yr. I run it at Canadian Tire Motorsport Park 'Mosport' (high speed -> up to 230km/hr but lots of running 145-170km/hr then braking) and Toronto Motor Sports Park (top speed 190km/hr, mostly lower speed corners 70-100 km/hr but fun!) Assuming your just driving and using your C63S day to day with perhaps 1-2 track days/yr, my advice for a W205 C63S would be:
Change Pads, not rotors for both front and back when you get a wear indication or noted that the pads are low during service. You'd have to make the call based on the rotor lip but realistically, I don't see it being necessary.
I replaced my front pads with the following: https://germanparts.ca/parts/B36026M
Here's the part for rear: https://germanparts.ca/parts/B13036M
At $215/CAD & $228/CAD plus the wear sensors. Great deal. The pads that showed were from an SL65, so same front calliper as a C63S. They were ceramic pads and have turned out excellent.
I'm running the original front rotors with those new pads but OEM replacement rear rotors and pads. They kinda got me on the rotor replacement, car was there, wear indictor was on and it wasn't an unreasonable repair. When they quoted almost $4k CAD to do the front pads/rotors, that's when I pumped the brakes and went hunting.
I've tracked the car multiple times/yr, drive it in summer and winter and it currently has almost 90000k on it, so I'm speaking from some pretty good real world experience.
I will have to address the front rotors and pads shortly as a full swap and I think the racing brake option is a great one. Appreciate the advice on those here. Going with the Brembo straight up would be marginally cheaper it seems.
#91
19 E63s, 23 M3 compX, B9 SQ5
This question has been asked before but typically what mileage are you guys having to repalce rotors and pads? I'm just about to hit 15K miles and on original pads and rotors... Pads about half life left, and rotors still going strong. Just street driving no tracking.
#92
- you're normal driving habits
- whether you use cruise-control a lot, especially with lots of downhill
(apparently MBZ uses the back brakes, only, to slow when on cruise control)
- whether your driving often invokes traction/stability control (uses braking)
- whether you track the car, what track(s) you run and your braking style
Prior to tracking the C63 S, the front brakes had about 2 MM wear in about 13K km (about 8K miles). I just completed a track day at Mission Raceways, a track that's notoriously hard on brakes and tires and, even with careful trail-braking, I wiped about 5 MM off my front brakes in 58 aggressive laps. My previous less agressive day at the same track wiped about 3 MM off my front brakes in 63 laps. Yes, I'm now replacing my (essentially non-existent) front pads. Rotors appear good for 1 more set of pads, at least. $;-)
#93
Found these rear OEM replacements on E-bay-
Says genuine OEM replacement: $274.22 - looks like for the pair
https://www.ebay.com/itm/352090761454
#94
Personally, I wouldn't trust E-bay sellers for any critical part and especially not brakes ... or would that be breaks? #;-)
Given that FCP Euro's prices are not that much more than the E-bay price and given their warranty (which others have stated is real), I buy from them:
https://www.fcpeuro.com/page/lifetime-guarantee
KAHBOOM (06-10-2019)
#96
#100
Front:
Rear:
In stock.
Front:
Rear:
In stock.
Do you guys ship to Australia?
