C63/C63S AMG
Wiper Chatter issue? Any solutions?
Old Aug 31, 2017 | 02:44 PM
dp61627's Avatar
Mercedes C63S
I've read a lot of Benz owners have windshield wiper issues where they stutter/chatter when in use. I also have the issue but only with light rain. If it's heavy rain, the wipers are usually smooth. I went to the dealership and they replaced my wiper blades. However, I still have the issue just not as bad. They mentioned not to use Rain-X on the windshield, but wouldn't that make it better and easier for the wipers to glide across the windshield?
Any solutions or tips for the stutter/chatter will be greatly appreciated since it is fairly annoying!
Old Aug 31, 2017 | 02:52 PM
dp61627's Avatar
Mercedes C63S
Originally Posted by Plutoe
Buy OEM and don't expect them to last the life of the car!
Are you referring to OEM wipers? I do have the OEMs still.
Old Aug 31, 2017 | 04:13 PM
Gungaslow's Avatar
2017 C43 sedan
I try not to drive my car when it's raining... it works for the wiper issue
Old Aug 31, 2017 | 04:22 PM
hyperion667's Avatar
2012 CLS63
I keep my windshield clean, blades clean and replaced.........still get the chatter on both of my cars.......drives me absolutely crazy......my wife's Honda Pilot wipers make me jealous.
Old Aug 31, 2017 | 07:56 PM
RDOCA's Avatar
2016 C63S Sedan
I also have the problem and they also have changed the blades. They also have a tool to check the arm angle. I use a glass wax that does a great job of cleaning the glass and making it slick. that helps some but the wipers really suck on this car. Then with rain-x you almost don't need the wipers on. There was another thread on this issue.
Old Sep 2, 2017 | 11:28 AM
Spar7's Avatar
Aventador SV / 991 GT3RS / C63S / M4
Don't ever use rain x on the front windscreen...in fact I don't use anything on my windscreen. Trust me I have tried all sorts of different brands and products that claims to not cause any chatter but none has lived up to their claims in my experience.
I tried at least 3 products on my c63s and ended removing everything..now I don't have any chatter issues..
I used Carpro Ceriglass and removed any coatings I put on and it works like a charm. To be fair since day 1 it already chattered but I though by applying something it would help but nothing worked only when I cleaned it with Ceriglass did I not notice any chatter..also if u already applied anything directly to the wiper blade u will need to replace them too
Old Sep 2, 2017 | 09:43 PM
kevjung's Avatar
2018 AMG C43 Coupe
Don't ever use RainX for windshield. It works for the first few weeks but after that the layer gets baked and weathered into something worse. This weathered RainX layer then wreaks havoc on the windshield wipers with stuttering and noises when being used. It's also really hard to remove - I had to clay bar it out.
Old Sep 3, 2017 | 06:56 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
It is one of my major annoyances with this car. Factory blades. Nothing on the windshield.
It rains a lot here. I buy cars to drive, so see no reason to not drive in the rain (I drove my 911 Turbo through 4 Iowa winters -- with snow tires).
I may try aftermarke blades, but it is annoying as hell.
Old Sep 3, 2017 | 06:58 AM
Spar7's Avatar
tscales
try ceriglass worked for me
Old Sep 3, 2017 | 10:19 PM
amg8's Avatar
MY17 C63s Sedan
I also have chatter however I am in a slight different situation. I put on Clearplex from day one so I don't really know if there was a chatter before that. But I am sure Clearplex is not as slick as OEM glass thus the chatter. So if anyone else has Clearplex or similar window "bra" on, please let me know how to get rid of the chatter. I was also told NOT to use Rain-X especially on Clearplex.
Old Sep 3, 2017 | 11:45 PM
BallzOne's Avatar
Mazdaspeed
I installed Bosch Ikon blades and treated the windshield with Aquapel, no issues with chattering.
Old Sep 3, 2017 | 11:51 PM
timannnn's Avatar
2014 E350
I have the original factory blades. The trick is to keep them clean using 303 Aerospace Protectant or a product called PERL. I use both for detailing and clean them every time I detail my car. They are super smooth and look like new. They have never chattered at all. The blades are super easy to remove.
Old Sep 4, 2017 | 11:21 AM
Bluetonic's Avatar
2017 AMG C63S Coupe, Triumph 675R Daytona, Triumph Explorer.
I had this after using a RainX like product (nanolex glass sealant), but a lot of cleaning products use similar type solutions to repel water so you could have had this applied inadvertently.
Disclaimer: This worked for me, but it took a few passes over a few weeks to completely solve the issue.
Coke (or Pepsi depending on preference). Full fat and not diet or zero etc.
Let it go flat and pour a small amount onto a cloth. Wipe all over your screen, try not to get it in your trim and DONT do it in direct sunlight.
Give it 5 min to settle and wipe off with a clean microfibre. If you have any smears wipe away with some clean water.
By the time I tried this I had gone through isopropyl alcohol cleaner, several different types of screen cleaning from Auto Finesse, auto gym and Meguiars. None of which helped. First application stopped the wipers from jumping about, a week later did the same again and all the stuttering was gone, now I've not had any problems since and the wipers work perfect.
Sounds crazy I know but give it a try and see if it makes a difference. It wont cost anything OR damage your car but could save you a lot of money on new blades.
Old Sep 4, 2017 | 12:17 PM
ItalianJoe1's Avatar
2003 CL 600
The dealer has a bulletin about this, the first step is new wipers but that's never enough. There is a layer of some sort of protectant/contamination, it's on every windshield, possibly from assembly or transport. There's a special cleaner we use as the second step of the bulletin, that takes any products off the glass. Works very well, if cleaned properly the issue usually does not return. I've used the cleaner on my old CL, which started chattering after installing new MB wipers, and it cleared it up.
The problem is the compound used in the wipers, but MB won't change it, and as long as the glass is actually clean the blades work well, so that's the solution.
I'll try to link the bulletin here tomorrow, but have your dealer use the "intensive cleaner" and do it properly, it will stop the chatter.
Old Sep 4, 2017 | 08:40 PM
Will617's Avatar
2016 C63S
I had the same issue at first but I always use rain-x after each wash and dry it with lots of paper towels and buff it. No issues since.
Old Jul 7, 2018 | 09:32 PM
JWreck's Avatar
C63 S AMG, Jaguar F Pace S
Hi, does anyone have links to non-OEM wipers you’ve bought that fit our vehicle and work well?
Old Jul 9, 2018 | 01:21 PM
Johnny Wang's Avatar
w205 c63s edition1
You can buy PIAA wiper to solve this problem .
Old Jul 9, 2018 | 09:17 PM
NYCSoiL's Avatar
2018 GT R; G82; M340
Do you have a link?
Old Jul 9, 2018 | 10:12 PM
w205 c63s edition1
Originally Posted by NYCSoiL
Do you have a link?
I have picture of the PIAA WIPER. I am form Taiwan ,so I don’t know where can get in America. If you are buying PIAA wiper . Need to check if it has E clip in the package to fit on w205
Old Jul 9, 2018 | 10:53 PM
JWreck's Avatar
So what makes PIAA different or better than Bosch Icon?
Old Jul 10, 2018 | 12:49 AM
KJ's Avatar
KJ
2020 GLE 53 AMG
https://thewirecutter.com/reviews/be...-for-your-car/
Old Jul 10, 2018 | 12:41 PM
w205 c63s edition1
I don’t know what makes PIAA different . someone test out several brands and found out PIAA is the best one to totally solve this problem.
Old Jul 22, 2018 | 12:25 PM
JWreck's Avatar
Ok so I bought the same exact PIAA wipers in your picture but they did not come with the “e clip”. Any ideas where to source that?
Old Oct 8, 2018 | 01:40 PM
KDLady's Avatar
2018 C300 Coupe
PIAA SI Tech Silicone
Just spoke to PIAA as 97055 is the size they told me to buy for w205. They will not have the E clip adapter until the end of November. Once they do, it will be included in the packaging.
