Michelin PS4 tire pressure
So it really depends on what you're doing at what time.
That means for most of us most of the time 38 front and 33 rear.
I just put on one size up Mich. Pilot 4S and Had the Americas Tire guy check in his computer if the recommended pressure was any different.
It shows the same for the original PSS and the one up size P4S.
From cold to hot at normal speeds you will get about 3 degrees increase and more with more speed or track /canyons.
I am going to try 39-34 and watch wear. It was quite even on the old ones except the front inner wear many are seeing from camber.
mid 40's really sounds too high... But the gas cap lid absolutely does say mid 40's somehow.
So if I'm checking and it's 90 deg. F and it looks like all the evenings are going to be a cool 60 deg. for the next while, I'll add +3 PSI and set for 41/36.
That way, the pressures are never low and the car will be set for any high speed runs.
My rear tires are almost shot (PSS) and i want to switch to the P4S in the rear (+front when those are done).
1) Is it okay to have the 2 different tires on front and rear?
2) if its mainly 2 people in my car, what should the tire pressures be? I think mine are 34/36 right now?
I'm personally going to go wider in the front and the back [probably 255/35-19 front and 275/35-19 (or even 285/35-19) back]. So I'm going to change all 4 tires at once and keep the front's in storage for when the time comes to sell the car.
2. Pressures should be 38/33 (F/R) cold (as per lid on fuel filler door). The front's should be higher than the back. Your pressure's are way off.
I just put on the 255/275 Mich P4S on mine and have not had time to use much yet.
I would say stay with 275 on rear if using stock wheels as it will keep the ratio front and rear the same so the ESP won't be seeing a difference.
