Hardwired Escort Max2 - 2018 C63S Coupe (explained w/ photos)
1. I used driver side fuse box and located fuse slot #217 which is designated as "Emergency vehicle/Special-purpose vehicle". I use the term "slot" because it was empty and only had a hole for one pin of a standard sized fuse. #217 is switchable (0 volts when car off, 12 volts when car/acc on). Other threads and a video online show people using slot 218 or 219 which are for the "Airbag System." As many pointed out in other threads, this seemed like a really bad idea to me. I also didn't want to use any of the fuses in left column of the fuse box because you would have to remove a black plastic bar that secures the entire bank of fuses in place and the clearance for the add-a-fuse isn't ideal.
2. Next, I placed a standard sized add-a-fuse connector with a 5A fuse in it (and an insulated female quick connect crimped to it) into slot 217**. I attached the positive lead of the Escort brand wire to the add-a-fuse and the negative lead to one of the metal bolts of the door jam located within the anterior portion of the fuse box. **an alternative option is to use this- which is essentially the same thing as the brown fuse holder that is occupying slot #216 in the picture below. It is designed to plug into these single hole fuseslots.**
3. I ran the power cord up the A-pillar to the headliner and across to the rear-view mirror housing. All of the wire was tucked under the trim pieces by gently prying a gap open using a plastic trim tool. I zip-tied the power cord to one of the other wire harnesses within the mirror housing to create a leash for the radar detector should the mount inevitable lose suction in the scorching hot Texas sun.
4. Last, I ran the portion of the wiring that connects to the "Smartcord" unit up through the posterior-superior aspect of the fuse box. This wiring nicely in the crevasse and the shape of the smartcord unit snuggled right up against the natural curves of the dash. This was achieved without using any adhesives, Velcro, etc. It has zero play and clears the door even when closed vigorously. The remainder of the wiring was bundled, twist-tied, and tucked away before replacing fuse box cover.
Hope this helps and saves some of you the frustration I went through trying to get this figured out. It was WAY easier in my M4 - all I needed was a mirror tap and a blend mount....
Cheers,
Harry
Thanks for the write up. But how do you remove the driver side fuse panel/door without breaking anything? I once tried that and it wouldn't come out and I didn't want to force it. Perhaps you can give insights as to the proper way to remove the panel/door?
Gently pry/pop it open first at the 3'oclock position (if you are looking at the fuse box cover while standing beside the car). Then gently pry/pop at the 12'oclock and 6'oclock positions. At this point, the box door should open as if you were turning the page in a book. Once open, you can fully pull the cover to the box off.
So I was able to get the panel off to access the fusebox however I don't see an immediate location to ground the wire. I see two BIG bolts which may work however those are way too big so I rather not use them. Other than those, I didn't find anything else in the immediate area. Do you by chance have a pic of where you grounded it?
Thanks!
The website said it should take about a week to arrive from the UK so I'm expecting them any day now.
If you want a really bad *** setup and don't mind forking over $1500 or so, then this is what I would recommend...
https://www.escortradar.com/max360c/
paired with
https://www.escortradar.com/zw5directwire/
The only real real benefit to “just” detecting laser (rather than jamming or shifting like the Z5W) is that it gets uploaded to the cloud and alerts other drivers using the escort system that there is laser being used at a particular location. This has saved me many times
- It doesn’t stay ON consistently when car is running. Seems like power source isn’t secure because going over a bump could get it to turn ON or OFF (literally). Not even sure where to begin troubleshooting or figuring out removing the whole setup.
- I really don’t like the location where the control module was placed. If I keep the setup, I’d like to conceal it in a better spot.
