Tire pressure and brake pads - help?
What pressure should the front and rear be? usually 2 people in the car.
Also, my brake pad life when they took off the rims to change tires appeared to be 40% front and 10% rear left.
Rear I should get changed ASAP i assume. Should I just order pads online and go to an indy shop?
Fronts AP1291 R4-S
Rears AP1669 R4-S
Theres a few people running these on here with only good reviews.
I purchased both sets of pads with shipping to Australia for the same price as the set of genuine mb rear pads that I bought a couple of months ago from mb parts.
Brake dust is apparently reduced dramatically over the genuine pads.
Fronts AP1291 R4-S
Rears AP1669 R4-S
Also, my tire pressure was set to 50 front / 54 rear...
Im thinking thats WAY too high?
How many miles do you have on your car that you're so low on brake pads?
I just put on the Mich 4S in one up size to 255 f and 275 r and the recommendation is for same pressure as OEM size
My firsts set had perfect wear across the tread and they ride much better than the high pressures.
They will go up about 3 degrees or so when driven at normal speeds from cold .
Going into the fall and winter the temps will drop and so will the tire press so unless you check them each week you could compensate with 1 # higher cold settings.
The shop guessed 10% on my rears and 40% on my front pads.
Does our car tell us when the pads need to be replaced or am SOL and pads + rotors have to be swapped if I miss the timeframe?
SD AUTO TECH (Now Carbahn) quoted me $880 for rear pads + rotors + install while MBZ dealer quoted me $1300.
. I'd inspect them first. Just look at all the outer ones with a flashlight, thru the spokes, and report back. It'll take you a few minutes, including snapping pics. New pads are typically about twice the width of the backing plate, so that will give you some indication of life left. Somebody with specific MB experience can tell you how much you have left with a good picture, but it's more or less twice the thickness of the backing plate for OEM pads. Good luck.
. I'd inspect them first. Just look at all the outer ones with a flashlight, thru the spokes, and report back. It'll take you a few minutes, including snapping pics. New pads are typically about twice the width of the backing plate, so that will give you some indication of life left. Somebody with specific MB experience can tell you how much you have left with a good picture, but it's more or less twice the thickness of the backing plate for OEM pads. Good luck.I do go on weekend drives with some hard accelerating then hard braking... will report back with pics when I get home.
. I'd inspect them first. Just look at all the outer ones with a flashlight, thru the spokes, and report back. It'll take you a few minutes, including snapping pics. New pads are typically about twice the width of the backing plate, so that will give you some indication of life left. Somebody with specific MB experience can tell you how much you have left with a good picture, but it's more or less twice the thickness of the backing plate for OEM pads. Good luck.Rears have only one sensor on the drivers side pad of a RHD car and my passenger side was the side that wore down to metal.
Luckily, my rotor only required a light skimming and not replacing.
My drivers side pad which is fitted with the sensor was still quite a bit away from triggering the sensors.
My suggestion is to check your pads periodically as part of your personal maintenance/washing of the car and DO NOT rely on the pad sensors...
As for the front, my last service at the dealership reported back that they wanted to change the front pads as they were low.
I didnt have them change them out as I wanted to upgrade to the Porterfield pads but inspected them once I got home.
As I suspected, front pads have at least the same thickness as the backing plate.
Im not sure if the front pads have sensors or which side its located on so I have placed an order for the Porterfield pads and will have them fitted when required.
My my personal experience with this car is check check and check brake pads and tyres...
. Thx.
Determining if the rotors are still good is a bit tricky and the thickness should probably be measured. At 14,000 miles, even with some hard driving, I would say you should be ok. Try running your fingernail along each rotor and see if it feels smooth or rough, if there are any rough spots or scratches or anything that looks warped you'll need new ones.
If you're slightly mechanically inclined the pads are easy to change yourself. I changed all 4 of my pads for about $220 in about an hour. If not, buy the pads online from Porterfield and take it to an indie shop.
Rear rotors are cheap. Front are expensive ($500-$1,000 each).
For the rears I believe OEM rotors are $150 each, you can look them up on OEDiscount.com so $300 for both rear rotors plus a set of rear pads from porterfield are $120 for the set. That brings us to ~$420 in parts. Labor I would say should be 1 hour @ $150/hour. So I would say $600 for just the rear at most.
The pads for rear were showing qty 1 = $120. is qty 1 = 1 set? Im a bit confused.
$120 is for a set. I was multiplying by 2 above because I thought your quote was for all 4 pads and 2 rear rotors. The rear pads I got from porterfield were $119.95 for 2 pads in the rear. The part number is: AP1669 R4-S
I went with Hawk front pads from Amazon: https://smile.amazon.com/gp/product/B014ME9TH4/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
But porter field may have front pads that are just as good, you can email them and ask which ones to use.
C63 Right
MSRPCore ?Online Price$150.00$0.00$112.50View Part Diagram -- Item #1REAR SUSPENSION / REAR SUSPENSION / BRAKE COMPONENTS / ROTOR2314230212 - rotor
C63 Left
Is it these items? How long do they usually take to ship?
