H&R lowering springs c63s
surprisingly I had 0 issues with HR spring on my 2017 C43.
I'd only recommend though if you're prepared to use something like the KMAC kit to get your camber correct otherwise it will be way out as mine was.
I don't think there's enough warming on how far out your car will be if you simply lower it.
What I do know is that the ride height sensors need to be programmed to recognize the lowered ride weight as “normal” to allow comfortable range of suspension travel while still preventing bottoming out.
