C63/C63S AMG
Al13forged wheels 295 wide tire set up.
Old Feb 8, 2018 | 09:58 PM
darwin329's Avatar
w205 c400 c63s
Al13forged wheels New shoes
fat tire
Old Feb 8, 2018 | 10:27 PM
C63S8ABMW's Avatar
2016 C63 AMG S
Specs?
Old Feb 8, 2018 | 10:31 PM
C63S8ABMW's Avatar
2016 C63 AMG S
I just ordered my new Wheels they should be in, in about a month or so. New set of HRE R101's in Satin Bronze. David @ Wheels Boutique hooked it up. I will be putting 305's or 295's on my rear as well. But we will see what works best. My shop thinks I can make the 305's work.
Old Feb 9, 2018 | 08:46 AM
Schulminator's Avatar
2015 C63s Sedan
Looks great, what are the wheel and tire specs. Getting my CCW's mounted up today....
Old Feb 9, 2018 | 08:49 AM
alexasa's Avatar
c
nice, would be looking the business if the front were a **** hair lower, IMO.
Old Feb 9, 2018 | 10:06 AM
midareff1's Avatar
2018 C63S Sedan
Very bad axx looking. Did you change the offset or width of the rears?
Old Feb 9, 2018 | 02:15 PM
darwin329's Avatar
w205 c400 c63s
Smile
side shot
close up
Originally i was running these michelins tire 255/35/19s front & 295/30/19s rear on cross spoke OEM wheel. The tires were bulging especially in the rears since i was running 8.5 fronts & 9.5 rears but no rubbing issues at all. Currently running Al13forged wheel 9.5 x 19s front & 10.5 x 19s rear. Very nice, Fancy & light wheels too. It makes a lot different when you run the right size tires 295s on the right wide wheel size like 10.5 handling is way a lot better straight and cornering! Over all the car looks very meaty. After 2 weeks of driving the car with no issues i decided to lower it by .70 inch and it started to rub in the rears! I know a lot of c63s sedan here were running 295s rear on stock wheels lowered with no issues at al but once you change the wheel to make it more wider like 9.5 fronts and 10.5 rears thats were you start having issues. I have a pretty aggressive set up since am running 3pc stepped LIP on 19s and still manage to have a good amount of concave ( see side shot photos) Correct me if am wrong the more aggressive offset the more concave but the wider wheel you get for the c63s sedan the more you have to be conservative on the offset and you ended up pretty flat centers. With the help of camber kits front and rear and fine tune in the alignment shop now i can say 255 and 295 is the widest i can go no issues. Later i might go back to 285/30 19s and tune my camber to 1.8 degrees hopefully let see... hehe I really like more TRACTION/ grip
on a straight line.
Old Feb 9, 2018 | 02:22 PM
AutoTalent's Avatar
SPONSOR
G55
I love it!!
Old Feb 9, 2018 | 06:00 PM
darwin329's Avatar
w205 c400 c63s
Smile
Originally Posted by AutoTalent
I love it!!
Thank you
Old Feb 9, 2018 | 06:09 PM
darwin329's Avatar
w205 c400 c63s
Thanks mate. width is 10.5 rears offset i will verify w/ the company i think its ET58
Old Feb 9, 2018 | 06:12 PM
darwin329's Avatar
w205 c400 c63s
Would be really nice if you can fit 305's with 11 wide wheels mate with lowered suspension. Good luck brotha.
Old Feb 9, 2018 | 06:15 PM
darwin329's Avatar
w205 c400 c63s
Thanks mate. You must be excited hehe i just posted the wheel spec
Old Feb 9, 2018 | 06:16 PM
darwin329's Avatar
w205 c400 c63s
Thanks mate
Old Feb 9, 2018 | 09:06 PM
2015 C63s Sedan
Did you notice where in the rear it was rubbing? My rears are 10" 50et and have a little bit of room inside, but not a whole bunch.
Old Feb 9, 2018 | 09:32 PM
darwin329's Avatar
w205 c400 c63s
Hey mate 10.5 Standard height no issues at all @ ET58 295s. lowered rubbing the FENDER when running 70 miles per hr approaching uneven roads . After camber 100 percent no rubbing but still 295 i believe it pushing to the limit or probably the widest you can go or maybe I have aggressive offset on 10.5 wide.. Imight try 285 later on.
Old Feb 9, 2018 | 09:56 PM
RDO247's Avatar
C63S
[QUOTE=darwin329;7377599]
side shot
close up
I am loving this car st the moment...
Nice work mate!
Old Feb 9, 2018 | 10:24 PM
darwin329's Avatar
w205 c400 c63s
[QUOTE=RDO247;7377941]
Nice work mate!
Thanks RDO247. Thanks for helping with the camber kits and when i was deciding with the 295 on OEM wheels
Old Feb 10, 2018 | 03:40 AM
RDO247's Avatar
C63S
[QUOTE=darwin329;7377954]
No problems mate.
Your car looks awesome. Congrats
Old Feb 10, 2018 | 08:36 AM
oajr's Avatar
2018 Mercedes C63s AMG
I absolutely love the look as well......black wheel center caps and it would be perfect in my eyes. Really well done.
What spring kit kit is installed?
Old Feb 10, 2018 | 11:13 AM
darwin329's Avatar
w205 c400 c63s
[QUOTE=RDO247;7378059]
No problems mate.
🙏🏼🙏🏼🙏🏼😊 Thank you
Old Feb 10, 2018 | 11:14 AM
darwin329's Avatar
w205 c400 c63s
Thanks you. Currently running h&r .70 or .80 inch drop only
Old Apr 4, 2018 | 10:56 AM
g2lujinn's Avatar
2017 C63S Sedan
Hey mate, nice tires! I'm getting 295/35/R19 for my rear and 265/35/R19 for my front, and I'm also considering lowering my car, just wondering what camber kits did you get? And does H&R spings give you any noise? Thank you!
Old Apr 4, 2018 | 04:03 PM
darwin329's Avatar
w205 c400 c63s
Hey mate! Am running kmac camber kits. H&R no noise and i was surprise h&r have better ride than stock!
Old Apr 4, 2018 | 07:32 PM
RDO247's Avatar
C63S
Im running Front and Rear K-Mac with KW HAS...
Super with the look and ride...
Old Apr 4, 2018 | 07:45 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
How did the wheels turn out mate? - Any pictures?
